TDI Poor Performance: Troubleshooting & Help
Cupra
Post08-10-2002, 11:44    Subject: TDI Poor Performance: Troubleshooting & Help Quote
Hi!
I'm new here and already have a question...
Ich fahre einen Cupra TDI, welcher laut Leistungsprüfstand 164 PS und 330 NM hat. Trotzdem ist der Wagen im Durchzu total schlapp. (Im vergleich zu anderen Cupras fehlen ca. 2 sec. beim Beschleunigen von 60-100 im 3. Gang)
All measurements are within acceptable limits (according to the diagnosis).
I hope someone can help me.
Markus.
Translated on 28-10-2026, 6:28.
Michael II
Post08-10-2002, 11:56    Subject: TDI Poor Performance: Troubleshooting & Help Quote
Could you please post the measurement readings?
Tschüss
Michael II
Translated on 28-10-2026, 6:29.
Cupra
Post08-10-2002, 13:14    Subject: TDI Poor Performance: Troubleshooting & Help Quote
Sure:
P-Norm: 118.5 kW
P-Mot: 120.4 kW
P-Rad: 97.1 kW
P-Towing 23.3 kW
Torque: 329 Nm.
The values are all okay.
Even with multiple memory reads... No errors displayed!
All values were measured while driving. All are within the normal range.
However, the expert from Seat and I agree that there is not enough power.
As I also noticed from the comparative measurements in the Seat Leon forum.
Is there a description of the ULF test available anywhere?
It might provide further insights...
Sure, here's the translation:
'Thank you.'
Markus.
Translated on 28-10-2026, 6:30.
Michael II
Post08-10-2002, 13:22    Subject: TDI Poor Performance: Troubleshooting & Help Quote
Sorry, I probably didn't explain myself clearly. I meant the measurement data from a diagnostic run (where current data is saved from the engine control unit). Your Seat dealer can probably do this for you.
Tschüss
Michael II
Translated on 28-10-2026, 6:31.
Cupra
Post08-10-2002, 13:35    Subject: TDI Poor Performance: Troubleshooting & Help Quote
I'll also check the values, but probably not until tomorrow or the day after. But as I mentioned, they are all within the normal range, not a single one is below the expected level.
Markus.
Translated on 28-10-2026, 6:32.
Post08-10-2002, 14:37    Subject: TDI Poor Performance: Troubleshooting & Help Quote
That could
provide further insight...
Hi Markus,
We haven't written a user manual yet...
In short:
Please enter all the required vehicle data or measure it during the rollout test.
Then the calculation will output an approximate target time.
Once the actual time has been determined, you can adjust the target time by entering values in the fields for over- or under-performance. This allows you to see how much power the motor is lacking or producing based on the changes you've made.
Or use the "target value calculation" function (?) icon_redface.gif, which I haven't tried yet.
Translated on 28-10-2026, 6:33.
No new posts Golf 1J Radio Issues: Troubleshooting Guide (KW 43/98) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Help needed: Oil in the coolant hose on a 1.5 TDI Diesel Engine Technology
No new posts VTG (ALH) Cleaning: Get Help & Tips Now! Diesel Engine Technology
No new posts AGR Valve issue on AAT - Need assistance Diesel Engine Technology
No new posts Large Pressure Canister Conversion Help Diesel Engine Technology
