Common Rail Tool Set for Timing Belt Replacement
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post20-04-2022, 12:10    Subject: Common Rail Tool Set for Timing Belt Replacement Quote
Hello everyone,
For my 1.4 Polo TDI, I used the Hazet 2588/3 tool set for the timing belt replacement. That worked great.
What part number do I need for the 2.0CR engine for KW, NW, and HDP?
Brezelmann01
dieselschrauber and brezelmann01 likes this.
Post20-04-2022, 13:54    Subject: Common Rail Tool Set for Timing Belt Replacement Quote
Hi Brezelmann,
I don't use a single, all-in-one solution for my CI/CD; instead, I use individual tools.
- KW Stop T10050;
- Centering pin 3359, 2 pieces, for inner wheel and outer wheel (or mandrel, drill bit d = 6 mm).
- Counterweight for the N (homemade).
- Very long key for turning the crankshaft (homemade - ring wrench with a flat bar attached).
- same, for relaxing the tensioner roller of the KRR system;
The kW stop value may vary from engine to engine, and it looks different in the Golf 7 with a 1.6L TDI engine. Ask about RLF.
brezelmann01
dieselschrauber likes this.
Post22-04-2022, 9:27    Subject: Common Rail Tool Set for Timing Belt Replacement Quote
Okay, so the KW stop and the alignment pin need to be taken over.
OEM T10050 = Hazet 2588-1
OEM 3359 = Hazet 2588-3
I just need to buy one more marking pin. I'm going to use original/Hazet parts here, as this one is hollow-drilled, presumably to allow air to escape from the guide.
Thank you!
Post22-04-2022, 13:44    Subject: Common Rail Tool Set for Timing Belt Replacement Quote
You'll need two probes, one for the front wheel and one for the rear wheel. A simple 6 mm pen will really do the trick.
brezelmann01
Post04-06-2022, 9:05    Subject: Common Rail Tool Set for Timing Belt Replacement Quote
Hi!
Is there a recommendation for a reasonable camshaft holding tool for home use that is below the price range of Hazet?
Brezelmann01
klahaui
Avatar-klahaui
2019 Volkswagen Golf
dieselschrauber and Herbert likes this.
Post04-06-2022, 12:21    Subject: Common Rail Tool Set for Timing Belt Replacement Quote
Hi Brezelmann,
Build your own counterweight. Material: €20, Time required: 30 minutes.
It has been providing its service to me for almost 10 years.
 File size:  3.89 MB
 Viewed:  481 times
 File size:  3.07 MB
 Viewed:  289 times
Post04-06-2022, 13:00    Subject: Common Rail Tool Set for Timing Belt Replacement Quote
Hello!
DIY - You'll need a flat bar, two screws with a head diameter that fits the holes in the crankshaft pulley (top of the image), and two pins that fit the holes in the harmonic balancer (bottom of the image).
 File size:  6.27 MB
 Viewed:  225 times
brezelmann01
Post05-06-2022, 12:09    Subject: Common Rail Tool Set for Timing Belt Replacement Quote
Hmm. Okay. Do it yourself. Actually, I didn't want to, as I currently don't have enough time and I also don't know the dimensions.
Brezelmann.
Post05-06-2022, 13:39    Subject: Common Rail Tool Set for Timing Belt Replacement Quote
Caliper? I mean, I must have gotten the dimensions from somewhere.
brezelmann01
Post07-06-2022, 18:21    Subject: Common Rail Tool Set for Timing Belt Replacement Quote
Could you please tell me the thorn diameter you use for the counter-holder? You can't just easily measure the pressure without installing an additional pump and removing all the extra components.
Thank you!
klahaui
Avatar-klahaui
Post08-06-2022, 8:00    Subject: Common Rail Tool Set for Timing Belt Replacement Quote
I have M10 and M8 screws (with the M10 screw turned down to 8mm) installed.
VG
Thilo.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts TDI with Common Rail: Explained & Benefits Diesel Engine Technology
No new posts Common Rail vs. TDI: Which is Better? Diesel Engine Technology
No new posts Common Rail Injectors: LT 35 Refurbishment? Diesel Engine Technology
No new posts Common Rail Performance Loss in Iveco Multicar Diesel Engine Technology
