Automatic shift timing programming for Audi A6 quattro
Patrasch73rs
Post19-05-2006, 20:24    Subject: Automatic shift timing programming for Audi A6 quattro Quote
Does anyone have any idea if it's possible to reprogram the excessively long shift times of VAG transmissions, and if so, how does it work? I would be grateful for any help.
Translated on 10-07-2026, 19:44.
x world one
Post20-05-2006, 13:49    Subject: Automatic shift timing programming for Audi A6 quattro Quote
Which transmission?
Since you have an A6, I'm assuming it has the 5-speed Tiptronic transmission.
As far as I know, there's no one around here who can reprogram engine control units. Apparently, in the US, there are tuning chips available for the TT.
You can also switch the A6 to sport mode. This should make the gear changes slightly faster. Otherwise, depending on the mileage (over 60,000 km), it's a good idea to change the oil and filter in the Tiptronic transmission. That will help too. If you overfill the transmission slightly, you might also get shorter shift times. The shift times are also dependent on the hydraulic pressure.Is the TT really that slow to switch on? Or are you driving a diesel car?
Spritmonitor
Translated on 10-07-2026, 19:45.
Patrasch73rs
Post20-05-2006, 14:44    Subject: Automatic shift timing programming for Audi A6 quattro Quote
Thanks for the reply. I have a 2.7-liter turbocharged gasoline engine. I'll try changing the oil myself.
I increased the boost pressure and did a mild chip tune. Now, the shift times are noticeably worse.
Michael
Translated on 10-07-2026, 19:46.
x world one
Post21-05-2006, 10:01    Subject: Automatic shift timing programming for Audi A6 quattro Quote
Sure. Good decision. But don't be surprised by the prices, especially the oil price, which is quite high at almost €12 per liter for VW vehicles.
As I mentioned before, slightly overfilling [something] can also be beneficial. But don't exaggerate. Otherwise, I don't know of any other ways to tune a TT [car model] here in Germany.
Spritmonitor
Translated on 10-07-2026, 19:47.
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts Doku Golf 5, Problems with windshield washer/water system Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 4B Quattro: Short Circuit to Positive Terminal On-Board Diagnostics (OBD)
No new posts Audi A6 2.5L 180hp Quattro not running.:( Diesel Engine Technology
No new posts Audi A6 Avant: Humming Noise When Turning Diesel Engine Technology
No new posts Audi C4 TDI Automatic: Strange Shifting Behavior Diesel Engine Technology
