pa-mm6 Blaumann
27-05-2006, 2:52 Subject: Golf 4 TDI: Strange Noise When Engine Stops |
Hello.
I'm having another problem with my car.
When I turn off the engine, I hear this strange gurgling sound, as if air is still escaping from somewhere in the engine.
Does anyone recognize this? If so, what could it be?
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email. Audi SQ5 8R Cvub
Translated on 22-08-2026, 1:50.
Profile PM Email |
matthiasTDI96 Profi-Schrauber
27-05-2006, 9:57 Subject: Golf 4 TDI: Strange Noise When Engine Stops |
Yep, we just had that issue. It was about a refrigerant leak in the air conditioning system. Try using the search function; it was an A3 with ASZ, but I don't remember the exact details. It might have been about three weeks ago.
pa-mm6 Blaumann
27-05-2006, 11:41 Subject: Golf 4 TDI: Strange Noise When Engine Stops |
Hello.
Okay, I found it.
"However, it's not as he describes; for me, it happens even when the air conditioning is off, regardless of the temperature." Audi SQ5 8R Cvub
Translated on 22-08-2026, 1:51.
Profile PM Email |
Jan6K
27-05-2006, 19:30 Subject: Golf 4 TDI: Strange Noise When Engine Stops |
Perhaps it's the sound of the shut-off valve opening shortly after the engine stops? Just observe what happens when you turn off the engine; maybe you can associate the movement of the shut-off valve (which you can see through the pneumatic lever connected to it) with the noise.
January. 1Z5 CFHF  / AHB H4D
Translated on 22-08-2026, 1:52.
pa-mm6 Blaumann
27-05-2006, 21:25 Subject: Golf 4 TDI: Strange Noise When Engine Stops |
Hello.
"Is that the valve located on top of the intake manifold, where the vacuum sensor is connected?"
Translated on 22-08-2026, 1:53.
Profile PM Email |
Jan6K
27-05-2006, 23:43 Subject: Golf 4 TDI: Strange Noise When Engine Stops |
Yes.
"Mine makes a noise when I put it down, which might be what you're describing. Try this: open the lid and have someone place it down while you observe."
pa-mm6 Blaumann
27-05-2006, 23:46 Subject: Golf 4 TDI: Strange Noise When Engine Stops |
Hello.
Okay, thanks. I'll try it out sometime if it turns out to be the cause. If that's the case, what can be done?
Translated on 22-08-2026, 1:54.
Profile PM Email |
Jan6K
28-05-2006, 10:54 Subject: Golf 4 TDI: Strange Noise When Engine Stops |
Why should one? If it's the noise I'm thinking of, then it doesn't bother me at all.
Translated on 22-08-2026, 1:55.
