Error memory empty or no communication
christians
Post16-02-2010, 20:43    Subject: Error memory empty or no communication Quote
I've installed my third VP44. Ro80 sends greetings.
After the bleeding process proved to be a bit more complicated than usual this time, the preheating indicator light started flashing continuously.
Error codes as listed in the title. No issues with main control units or basic settings. Onboard voltage is okay.
After a 30 km test drive and several starts, an error code eventually appeared in the system's memory, listing all the issues that had occurred in the past few days. After deleting, the lamp was also off.
Question: Why couldn't I access the error memory initially? Is the MSG about to give up the ghost now too?
Gruß Christian
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climate control not cooling, error memory cleared Transmission, Chassis, Body & Interior
No new posts ABS Light On After ESP Change - No Codes? On-Board Diagnostics (OBD)
No new posts 2.8L V6 AAH - No communication On-Board Diagnostics (OBD)
No new posts "AdBlue error message, but fault memory is empty." Diesel Engine Technology
