Second (Hand) Gas Pedal Installation for TDI "DIY Project"
hb2000
Post02-06-2006, 9:04    Subject: Second (Hand) Gas Pedal Installation for TDI "DIY Project" Quote
Hello
Donor ½ for accelerator pedal position-G79+G185
Is it possible to connect a second 'gas pedal' as a potentiometer in parallel to the correct gas pedal?
or does this action immediately trigger an entry in the fault memory, and the system enters emergency mode? icon_rolleyes.gif
Greetings
hb2000
Post02-06-2006, 10:39    Subject: Second (Hand) Gas Pedal Installation for TDI "DIY Project" Quote
I had that idea too.
The accelerator pedal is one of the most closely monitored electrical units on the TDI. If you tamper with it, the EDC will immediately detect this and enter a fail-safe mode, they told me.
http://www.f-22raptor.com/pix/photos/cockpit/gal_142_b.jpg
Nebelwerfer_TDI
Post02-06-2006, 12:33    Subject: Second (Hand) Gas Pedal Installation for TDI "DIY Project" Quote
Possibly switch over so that only one sender is active at a time. This should be done using a switch, so that there is no interruption. Perhaps, when using 'hand gas', there should be a dead zone that activates a microswitch, which then, using a switch, performs the switching. Once the 'hand gas lever' is activated, it is after overcoming the 'dead zone' and thus completing the changeover.
Man, an F-22 throttle lever would be awesome.
as long as children play, they are healthy icon_lol.gif *duckandcover*
Post02-06-2006, 13:57    Subject: Second (Hand) Gas Pedal Installation for TDI "DIY Project" Quote
As long as children are playing, they are healthy. icon_lol.gif *duckandweg*
If someone is driving next to you on the highway and looking over your shoulder, you pull the lever, which is attached to the door panel, forward... and you're off.
Wow, I feel great!!!
Jan6K
Avatar-Jan6K
Post02-06-2006, 18:20    Subject: Second (Hand) Gas Pedal Installation for TDI "DIY Project" Quote
In the ancient Bundeswehr jeeps, this was very simple to implement using a Bowden cable, which simply pulled the gas pedal down. So, something like a manually adjustable "idle stop" for the accelerator pedal.
So, with simple mechanics, it should be possible to achieve this, but I have my doubts about whether it's actually allowed.
Maybe it's better to have it work directly with the + and - function of the speed sensor via a microcontroller...
To use the F22 thrust lever, you would also need to install a thrust augmenter... icon_wink.gif
Jan
1Z5 CFHF / AHB H4D
joegolf
Post03-06-2006, 12:44    Subject: Second (Hand) Gas Pedal Installation for TDI "DIY Project" Quote
However, I don't quite understand the purpose of the car. What is the purpose of a speed control system...?
Golf 7 GTI
tdi-schrauber
Post03-06-2006, 21:04    Subject: Re: Installing a Second (Hand) Accelerator Pedal on a TDI »DIY Project« Quote
Hello!
hb2000 wrote:
Is it possible to connect a second "gas pedal" as a potentiometer in parallel to the correct gas pedal
Contact a specialist workshop that specializes in adapting vehicles for people with disabilities.
They know how to do it.
E.g. E-gas via ring on the steering wheel AND normal pedal.
BYE
TDI-Mechanic
No new posts Installing a DAB/DAB+ antenna General Tips
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV TDI: Accelerator Pedal Signal Lost? Diesel Engine Technology
No new posts Manual Lumbar Support Adjustment: How To? Diesel Engine Technology
No new posts Hydraulic Jack: Manual Operation & Use Diesel Engine Technology
No new posts Exhaust Smoke: Diagnose Engine Damage? Diesel Engine Technology
