I can't find it...
mhernach
Post23-06-2006, 7:44    Subject: I can't find it... Quote
Hello everyone...
Can someone quickly help me? I'm having a problem with my Galaxy, a 2001 model with 115 horsepower, because it's not pulling well in the higher RPM range. It doesn't perform too badly under partial load...
According to VAG, I have insufficient air mass... a maximum of 700 mg.
Unfortunately, I can't find the test you're referring to. Which DIODE should I use, and which connections should I bridge?
Michael.
Post23-06-2006, 8:09    Subject: Re: I can't find him... Quote
mhernach wrote:
Unfortunately, I can't find the test, which DIODE should I use, and which contacts should I connect...
Well, in the LMM technical article , of course icon_razz.gif.
Nebelwerfer_TDI
Post23-06-2006, 9:03    Subject: I can't find it... Quote
Just remember that approximately 4.5 volts need to be applied to the output of the LMM (likely referring to a laser module monitor). So, it's clear how the diode needs to be connected - always with the ring towards the output.
When the diode is connected, the control unit (STG) detects a very high air mass, which, depending on the engine mapping, results in an above-average high exhaust gas recirculation (AGR) rate in the lower speed and load range. This could have a disruptive effect.
How's his loader doing? Have you already found a replacement?
mhernach
Post23-06-2006, 11:54    Subject: I can't find it... Quote
How is his charger doing? Do you already have a replacement?
Not yet... I'm still waiting for an offer.
'But it's really funny to ride like that when someone joins you and doesn't know how my bike normally works... My friend's last comment was: 'Wow, that thing is fast, it really pulls, especially with the car involved...'' 'How many horsepower does it have? 150 or even more?'
I was almost at my breaking point...
Okay, here's the translation:
'First, I'm going to try welding it in the car... I can't really do much more than that...'
Michael.
Nebelwerfer_TDI
Post23-06-2006, 12:08    Subject: I can't find it... Quote
First, I'm going to weld it in the car right away... I can't really do much more than that...
You're right, as long as there's no/very little mechanical involvement. It should last a while, depending on the load it's subjected to.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intake Air Temperature Sensor for Audi ARL Engine Diesel Engine Technology
No new posts Drive Shaft Joint: Not Found? Find It Here! Transmission, Chassis, Body & Interior
No new posts Could not find ROD file On-Board Diagnostics (OBD)
No new posts AJM: Find No Errors - Troubleshooting Guide On-Board Diagnostics (OBD)
