Daytime Running Lights on Fog Lights 3C
Post23-03-2007, 22:24    Subject: Daytime Running Lights on Fog Lights 3C Quote
Hi.
I was just modifying the settings on my Passat.
It now beeps when opening and closing (using the horn to acknowledge).
But.
Code:
Byte 17 Bit 4     Nebelscheinwerfer als Tagfahrlicht aktiv
He may take over, but things aren't working.
Oops, I see something now... I definitely need to check that out too.
Code:
Byte 00 Bit 3     Tagfahrlicht (Skandinavien) aktiv
or
Code:
Byte 00 Bit 4    Tagfahrlicht (Nordamerika) aktiv
nur Frontscheinwerfer bei gelöster Handbremse
activate?
Ah:
Therefore, they must be installed, and at least one of the TFLs must be active.
Code:
Blockiert werden
- Byte 17 Bit 4 (1), wenn 00/3 (0) UND 00/4 (0) UND 00/00 (0)
- Byte 17 Bit 4 (1), wenn 00/3 (0) UND 00/4 (0) UND 00/00 (1)
- Byte 17 Bit 4 (1), wenn 00/3 (0) UND 00/4 (1) UND 00/00 (0)
- Byte 17 Bit 4 (1), wenn 00/3 (1) UND 00/4 (0) UND 00/00 (0)
- Byte 17 Bit 4 (1), wenn 00/3 (1) UND 00/4 (1) UND 00/00 (0)
Translated on 15-09-2026, 2:17.
Avatar-Jan6K
Post24-03-2007, 11:06    Subject: Daytime Running Lights on Fog Lights 3C Quote
Does using fog lights during the day (without fog) cost 5 euros with the "Grüne" (environmental zone) in Germany? Or does your 3C model have fog lights that are also approved as daytime running lights (DRLs)?
Jan.
1Z5 CFHF / AHB H4D
Translated on 15-09-2026, 2:18.
Maxx1278
Avatar-Maxx1278
Post24-03-2007, 16:47    Subject: Daytime Running Lights on Fog Lights 3C Quote
Yes, TFL Scandinavia or America needs to be proactive.
I had the Scandinavian TFL and the TFL for New South Wales programmed into my Golf.
Works perfectly.
If you activate the TFL America feature, you will no longer be able to use the combination of daytime running lights and navigation system lights.
The only lights that are on are the navigation lights, and the stern light is not illuminated.
The parking light turns on, and the NSW (Night Vision System) turns off when the handbrake is engaged.
It's a really stupid circuit.
Therefore, I switched back to Scandinavian.
Best regards.
Maxx.
Translated on 15-09-2026, 2:20.
pc2
Post25-03-2007, 11:28    Subject: Daytime Running Lights on Fog Lights 3C Quote
Nebler, when used as daytime running lights, are allowed in Austria, but not in Good Old Germany icon_biggrin.gif.
Translated on 15-09-2026, 2:21.
Ross-Tech-Support
Post25-03-2007, 12:51    Subject: Daytime Running Lights on Fog Lights 3C Quote
pc2 wrote:
While fog lights used as daytime running lights are allowed in Austria, they are not permitted in Good Old Germany icon_biggrin.gif
It doesn't interest anyone, because as long as the parking light isn't on, every standard police officer assumes there are "separate daytime running lights." icon_twisted.gif
Avatar-Jan6K
Post25-03-2007, 13:40    Subject: Daytime Running Lights on Fog Lights 3C Quote
It doesn't really matter to anyone, because as long as the parking light isn't on, every standard police officer assumes there are "separate daytime running lights."
Looking at how many people in this forum alone have been stopped by the police for allegedly using fog lights, I would actually expect the opposite to be true.
Jan.
1Z5 CFHF / AHB H4D
Translated on 15-09-2026, 2:22.
Ross-Tech-Support
Post25-03-2007, 13:42    Subject: Daytime Running Lights on Fog Lights 3C Quote
Let's just say I've been doing it this way for about 5 months now, and I haven't had any problems.
Mephisto
Karma: +14 / -1   Thank you, like it!
Post27-03-2007, 7:30    Subject: Daytime Running Lights on Fog Lights 3C Quote
... whether or not you get pulled over depends on how you generally behave on the road.
"Micha"
Translated on 15-09-2026, 2:23.
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Self-activating" daytime running lights (6N, 1M, 1U, 1J) General Tips
No new posts Fogging systems before LLK inlet.:-(( Diesel Engine Technology
No new posts Covers off the nebulizers - why? Transmission, Chassis, Body & Interior
No new posts Daytime Running Lights VAG-COM Installation On-Board Diagnostics (OBD)
No new posts Dim Daytime Running Lights: How & Why Transmission, Chassis, Body & Interior
