Climatronic Error 214: Troubleshooting Guide
hollodero
Post07-03-2007, 11:53    Subject: Climatronic Error 214: Troubleshooting Guide Quote
I have a Golf IV, manufactured in 2000, with 90 horsepower, and AGR (adjustable head restraints). Recently, the Climatronic system has been displaying the error code 'hex214,' which, according to the error code description, indicates 'supply voltage (0x6 0x7).'
Can someone give me a hint about what this means and where the cause of it might be?
Sure, here's the translation:
'Thank you in advance.'
H.
Translated on 01-11-2026, 1:57.
Ross-Tech-Support
Post07-03-2007, 21:53    Subject: Climatronic Error 214: Troubleshooting Guide Quote
Connect a proper diagnostic system and read the fault memory of ALL systems correctly, then we can say something about the error. Your error code is incomplete; it's missing the error type (is the supply voltage too low or too high?). Furthermore, in this case, the other systems are particularly interesting, because only then can you decide whether to start with, for example, the alternator or the climate control system itself.
Translated on 01-11-2026, 1:59.
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Climatronic Error: Troubleshooting & Solutions:?: Diesel Engine Technology
No new posts Golf 4 Climatronic Error 1271: Fix & Troubleshooting Transmission, Chassis, Body & Interior
No new posts It is impossible to clear the error code for the V71 serv... Dieselschrauber Bar
No new posts Log Climatronic Upload
