klopfer Blaumann
Joined: 03/23/2003 Posts: 70 Karma: +6 / -0 Location: Solingen 2007 Audi A4 Avant Free account, no CAN development support
24-02-2005, 16:10 Subject: AC Actuator Motors: Buy Online Now! |
Hello everyone,
After I could no longer place my air conditioner on the windshield, I briefly connected my laptop and read the error codes  .
Wednesday, February 23, 2005, 09:49:01.
VAG-COM Version: Release 409.1-US
Control Module Part Number: 4A0 820 043 H
Component and/or Version: Klima-Vollautomat D05
Software Coding: 00053
Workshop Code: WSC 02315
4 Faults Found:
00779 - Outside Air Temperature Sensor (G17)
30-00 - Open or shorted to B+.
01272 - Positioning Motor for Center Flap (V70)
41-10 - Blocked or No Voltage - Intermittent.
00603 - Footwell/defroster flap positioning motor (V85)
41-00 - Blocked or No Voltage
01274 - Air Flow Flap Positioning Motor (V71)
After recovering from the shock, my question is: do all the servo motors share a common power supply, or should they all really be defective?
Thomas.
Audi A4 Avant 2,0 l TDI (MKB = BRD) Baujahr 01/2007
Translated on 20-10-2026, 21:47.
Profile PM Garage |
andre Guest
24-02-2005, 17:51 Subject: AC Actuator Motors: Buy Online Now! |
It looks more like a problem with the control unit or the power supply to me; it would be strange if 3 actuators and a sensor were to conspire to self-destruct together.
Or was there any event, perhaps something that was engineered or caused, that could have triggered the mass die-off? Or was there some kind of 'shortcut' involved?
Translated on 20-10-2026, 21:50.
klopfer Blaumann
24-02-2005, 20:01 Subject: AC Actuator Motors: Buy Online Now! |
It wasn't a specific event, but I simply couldn't switch it to defrost mode anymore (I could select it, but nothing happened).
"However, recently I've noticed water accumulating on the driver's side floorboard after heavy rain. I'm going to check if the connections might be corroded."
Thomas.
Translated on 20-10-2026, 21:51.
Profile PM Garage |
olli Profi-Schrauber
Joined: 05/24/2002 Posts: 581 Karma: +46 / -0 Location: Berlin
25-02-2005, 19:58 Subject: AC Actuator Motors: Buy Online Now! |
In the climate control system of the C4, as well as the B4, this is a known issue.
If you're lucky, it might go away for a while, but eventually, nothing will work at all.
Most often, the motors fail because the carbon brushes wear out. In that case, you can (if you're handy) replace them with brushes from MĂ€rklin.
It's also possible that a diverting lever or a control unit output has failed.
If my memory serves me correctly, there's a service manual for the climate control system of the C4 somewhere on www.meckisforum.de.
By the way, installation and removal are a real pleasure, especially for the servo motors that are not accessible from the engine compartment...
Best regards from Berlin.
Olli.
A6 CANA/JME /
'95 Cinquecento als Stadtgurke ~~ 124CS0 fĂŒr den Sommer...
Ex-A6 AEL
Translated on 20-10-2026, 21:52.
klopfer Blaumann
25-02-2005, 20:52 Subject: AC Actuator Motors: Buy Online Now! |
Good evening, everyone!
I spent the last two days disassembling the interior of my car to remove the stepper motors behind the center console (V70 and V85). That's a real job for someone who's already "killed" their parents. I went to the Volvo dealership, and they quoted me 170 euros. Now I'm just hoping that was the problem. I can pick up the motors tomorrow and will install them sometime this week, and then I'll report back.
If anyone needs installation and removal instructions, please let me know.
See you then.
Thomas.
Translated on 20-10-2026, 21:54.
Profile PM Garage |
26-02-2005, 12:02 Subject: AC Actuator Motors: Buy Online Now! |
I can imagine that an installation and removal guide would be very interesting for some people, as this problem seems to occur fairly often.
Olli.
A6 CANA/JME /
Ex-A6 AEL
Translated on 20-10-2026, 21:55.
wolle Blaumann
28-02-2005, 23:33 Subject: AC Actuator Motors: Buy Online Now! |
Do you want an installation guide? Here it is...
It's quite simple, but it still explains the essential points.
I'm always happy to answer questions or receive feedback.
Let's get started:
The two actuators, models V70 and V85, are located approximately 35 cm behind the...
Switch cover. Those with skillful fingers and patience will be able to do it.
without expanding the center console.
The most important thing is: After replacing a valve actuator, you must...
It is essential to perform a basic adjustment, for example, using VAG-COM, in order to...
Re-calibrate the flap motor, ensuring the correct end positions of the flap are set.
Der Fehler 11.5 ( statischer Block ) ist der Stellmotor V70. This.
"Error entry triggered by potentiometer G112, which is located in the..."
The steering motor is located here.
The V70 is located on the right side of the blower/heater box.
and has a blue connector, the V85 is located on the left and has a...
roten Stecker. Beide lassen sich nur mit Geduld wechseln. You are located.
sich auf einer TrĂ€gerplatte, die ausgebaut werden muĂ. DThe engines.
werden dann sozusagen auf dem Tisch ausgetauscht. Then it must be...
The mounting plate should be reinstalled.
It can be done without completely disassembling the center console.
then you'll have to accept some gymnastic exercises... (back of the head on the...).
Look at the floor of the car, towards the actuators.
(It's up to each individual to decide where the legs should go...)
Ich bin ĂŒber die Seitenverkleidung im FuĂraum rangekommen. DIe.
I didn't remove the center console. But I did remove the climate control panel.
The radio needs to be removed.
Okay, I'll try to list everything that's important from memory.
Tools: Socket set with 8 sockets, 10 sockets, Torx sockets, and one short socket.
Phillips head screwdriver, two long, thin flathead screwdrivers.
You might need to disconnect the red and blue connectors on the motors.
Remove the glove compartment with its frame and the driver's side footwell storage compartment.
After that, I ended up upside down in the footwell...
Then, disconnect the ventilation pipes on both sides, those that are directed towards...
Windshield display.
Detach the side panels of the center console (only the left side has a screw).
On the right side, it's clipped in behind. And then, only as far as it needs to go.
It's necessary to bend the part backwards to reach it with your hand and perform the required work. But be careful...don't bend it too far (risk of breakage).
A flashlight is very useful.
Looking for something to wedge in there to keep the trim from popping out.
Then you'll see a blue and a red joint linkage on each side.
Loosen the fastening screw (one for each joint) and then remove the joint.
subtract (don't worry, it only fits in one position)
Then, on each side, locate a screw on the plastic housing; the screws are upside down.
screwed in from the top; these release the base plate, where both...
Actuators are attached.
These screws need to be unscrewed.
(There is only one screw per colored joint, and one screw on the left side.)
and to the right for holding the base plate, on which the motors are mounted.
are)
The base plate is approximately 25-30 cm long, 6 cm wide, and about 4 cm high.
It is positioned parallel to the dashboard, running across the vehicle.
Now the real fiddling begins...
Die Grundplatte in Richtung Beifahrerseite heraus holen. This must.
prior to being positioned approximately horizontally.
(You need to, so to speak, orient the base plate towards the climate control panel.)
(click below to expand)
Once the mounting plate has been removed, the replacement of the...
Actuator motors are a piece of cake. You can then see where to place the motors.
must be unscrewed.
Der Einbau muĂ in umgekehrter Reihenfolge erfolgen. It's real.
It's a bit fiddly, but you save a lot of money doing it that way.
Don't forget: Reset the initial position!
That's it!!
That's all I can think of for now. Any ideas? Throw them my way. I think I'm going to write a technical article about it. Let's get started. I just need to revise the instructions a little... give me a little time... really, just a little.
Wool.
Translated on 20-10-2026, 22:01.
klopfer Blaumann
01-03-2005, 18:37 Subject: AC Actuator Motors: Buy Online Now! |
Hello wolle,
Then I probably followed your instructions, which I found on meckisforum. Thank you very much; it made things much easier, and now I don't even need to read the technical article  ).
"However, I completely removed the entire center console and also detached the bracket on which the radio, controls, etc. are mounted. Even with this disassembly, I was cursing like crazy. How you managed to remove and, especially, install the bracket with the actuators without disassembling the center console is a mystery to me... Respect!"
Everything is working properly for me again now!
THANK YOU
Thomas.
Translated on 20-10-2026, 22:08.
Profile PM Garage |
wolle Blaumann
01-03-2005, 22:58 Subject: AC Actuator Motors: Buy Online Now! |
Hi Thomas,
"No problem... however, the original instructions came from Kristian/Krissi. Because I also experienced these problems, I came up with the idea of a technical article. I revised it and today summarized it with some additional information in a technical article. I will expand the article further. However, I still need some more information for that. Some photos would also be great. Let's see what I can put together..."
I'll go ahead and publish the article, and then we'll see what happens.
Wool.
Translated on 20-10-2026, 22:09.
klopfer Blaumann
01-03-2005, 23:12 Subject: AC Actuator Motors: Buy Online Now! |
Unfortunately, I can't provide any photos; I'm still in the Stone Age when it comes to that, as I don't have a digital camera.
Translated on 20-10-2026, 22:10.
Profile PM Garage |
wolle Blaumann
01-03-2005, 23:17 Subject: AC Actuator Motors: Buy Online Now! |
No problem... I can take pictures of the two motors in the water tank myself. And I'll have to see about the two inside... whenever I read somewhere that someone is having a problem with them, they're immediately arrested...
mattesware
Joined: 06/04/2005 Posts: 1 Karma: +1 / -0 Location: Neustadt am RĂŒbenberge
04-06-2005, 14:58 Subject: I Did It! Success, Achievement, Goal Reached |
Hey Wolle,
Thank you for your excellent description of how to replace the V70 and V85 servo motors. I must say, I actually wanted to remove the center console, but thanks to your instructions, I managed to do it without removing it, and it only took me 3 hours. The servo motors cost me a total of 183 euros. You'll need to spend roughly the same amount on installation. In the winter, the servo motor for the hot air flap (V71) was defective. I managed the replacement without any help. Now, in the summer, the V70 was defective. I replaced both motors at the same time. Now I just need to have the servo motors "learned" and the error memory cleared.
Thank you very much.
Mathias.
99% of all computerproblems are sitting in front of the keyboard.
Translated on 20-10-2026, 22:11.
Profile PM Email |
wolle Blaumann
05-06-2005, 7:16 Subject: AC Actuator Motors: Buy Online Now! |
Hi Matthias,
*happy*
Thank you for your kind words!
I'm glad it worked out. That's how it should be...
Wool.
Translated on 20-10-2026, 22:13.
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
04-12-2006, 10:35 Subject: AC Actuator Motors: Buy Online Now! |
After experiencing the typical error messages and the heating continuing to operate even when "off" in the Climatronic system, as well as (frequently during acceleration on the highway) hearing the sound of the bypass valve opening and closing, the actuator motor was replaced by the factory service department, requiring a complete dashboard removal. However, shortly after this repair, the same errors have reappeared.
Tuesday, November 28, 2006, 4:46:56 PM.
VAG-COM Version: RKS 607.3-UD
Control unit part number: 3B1 907 044 H.
Component and/or version: CLIMATRONIC B5GP 0009
Software Coding: 17000
Workshop code: WSC 05311.
"One error found:"
01274 - Actuator for pressure relief valve (V71).
35-00 - -
Tuesday, November 28, 2006, 4:46:23 PM.
Engine Control Unit Part Number: 038 906 019 GL
Component and/or version: 1.9L R4 EDC G000SG 1495.
Software Coding: 00002
Workshop code: WSC 05314.
Additional information: WVWZZZ3BZ3E410146 VWZ7Z0C7074532
"One error found:"
18043 - Data bus drive: Missing message from the climate control unit.
P1635 - 35-00 - -
Self-test: 0 0 X X X
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Die Blumen blĂŒhen in allen Farben, und der Duft von frisch gemĂ€htem Gras liegt in der Luft. Die Kinder spielen ausgelassen im Sandkasten, und die Erwachsenen entspannen sich auf den BĂ€nken und unterhalten sich angeregt. Es ist ein perfekter Sommertag."
The latter is likely related to the installation of a Blaupunkt Casablanca MP 56 and its testing with the ignition on, but without the Climatronic control unit connected.
I deleted the errors and checked again today.
Monday, December 4, 2006, 10:06:26.
Control unit part number: 038 906 019 GL.
No errors found.
Monday, December 4, 2006, 10:06:56.
"One error found:"
35-00 - -
After the Climatronic self-test:
Monday, December 4, 2006, 10:12:05.
"One error found:"
35-10 - - - Sporadically
My questions are now:
"When I start the self-test and the Climatronic is set to 'off', the ventilation turns on, and I hear the test of the actuators within the first 1-2 minutes. Then, nothing else happens, and the fan continues to run. The only options I can select are 'Next/Continue' or 'Back'. Does the self-test indicate when it's finished? How long does it take? I stopped it after about 5 minutes."
2. Are there other reasons for the symptoms described above besides the stepper motor that is indicated as defective?
Is the new stepper motor broken again?
You're welcome, haithamina.
edit 1:17 PM:
I cleared the error codes and ran the self-test for 2 minutes. Then, I checked the measurement blocks 2-4 and adjusted the settings on the Climatronic (windshield deflector, middle vents, lower vents, recirculation, fan speed, etc.). All the motors are moving, and the displayed values deviate from the specified values by a maximum of one unit. Reading the error codes again did not reveal any new entries.
Translated on 20-10-2026, 22:20.
