PD Engine Tuning: 10 or 20 Cent Upgrade
Go to page: 1, 2  Next
smith2
Post03-07-2006, 10:41    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
Hello, I've already read several posts about the 10 or 20 cent tuning adjustments for VP engines.
I have also read Rainer's article several times.
I have a turbocharger in my Octavia Combi, and I occasionally want to extract a little more power from it.
I'm still not entirely clear about the modification involving the pull-up resistor – specifically, where it's connected. Where exactly does the pull-up resistor go, and what resistance values can be used? Should it be adjusted with a potentiometer, or is it better to use fixed resistor values? Also, does it need to be turned on with a delay?
What other options are there? Can the boost pressure be increased by 0.1 to 0.2 bar by changing the resistor? What resistor value corresponds to a change from 1.3 to 1.4 bar or 1.5 bar? Is it also 18k ohms for 0.1 bar and 27k ohms for 0.2 bar? I know that one should be very careful with this... because of the potential for overshooting and the regulator's sluggishness.
Are there any other methods? I don't want to use a pre-built solution where I don't know exactly what's inside and how much 'modification' is involved.
Thank you for the tips.
Translated on 12-10-2026, 13:08.
Rudi
Post03-07-2006, 11:22    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
Chip or 195 tires icon_mrgreen.gif.
Translated on 12-10-2026, 13:10.
smith2
Post03-07-2006, 16:21    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
I'm serious.
Rudi
Post03-07-2006, 17:33    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
Me too icon_twisted.gif.
'10 degrees Celsius at the VP sensors is already borderline. For the PD sensors, it's nonsense (fuel temperature fake).'
or expensive (uC Box) and, in any case, worse than a decent microcontroller.
Whether the extra power is used for increased acceleration or to compensate for the tire width.
Everyone must decide for themselves.
Rudi
Translated on 12-10-2026, 13:11.
Post04-07-2006, 7:15    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
smith2 wrote:
I don't quite understand the modification with the pull-up resistor, and where it is connected. . .
The FA refers to the MSA 15 generation from AFN and Co.
The pull-ups are located in the MSG. As for where to find the newer EDC 15 models now: I have no idea; everything is even more compact there than in the MSAs icon_evil.gif.
Otherwise, what Rudi already wrote applies: nothing beats good chip tuning (except good chip tuning plus sensible hardware modifications), but not without wide tires that negate the performance gains.
Translated on 12-10-2026, 13:12.
danko
Post04-07-2006, 8:48    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
Increasing the LD (lambda) value alone won't give you much benefit, and I would generally advise against manipulating the SG (slip gauge) without precise instructions. Especially when tuning PD (pressure distribution) engines, I wouldn't recommend making experiments with small adjustments like 10 or 20 cents.
CU Danko.
I just realized that the ASZ is actually a PD engine, so I've rephrased my previous post.
Skoda Octavia 1.9 TDI Elegance MJ2002
VP TDI 81kW (MKB ASV)
Translated on 12-10-2026, 13:13.
Herr Antje
Post04-07-2006, 8:50    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
For PD printers, larger nozzles are probably not as cost-effective, or icon_question.gif
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 12-10-2026, 13:14.
Rudi
Post04-07-2006, 9:23    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
For PD printers, larger nozzles are probably not as cost-effective, or icon_question.gif.
The bare nozzles are likely to be priced in the same range as VP nozzles, BUT the replacement process is...
not possible with DIY methods (unlike with VP holder combinations).
Rudi
Translated on 12-10-2026, 13:15.
smith2
Post04-07-2006, 15:59    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
Okay, then.
If you all strongly advise against it, I will refrain from doing it.
What about the newer Hopa boxes (DigitalDivo)? What's inside them?
Just for fun?
Thank you for your answers.
Post04-07-2006, 16:25    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
Okay, here's the translation:
/viewtopic.php?t=12448&highlight=digitaldivo
Translated on 12-10-2026, 13:16.
im-111
Karma: +0 / -4   Thank you, like it!
Post15-07-2006, 14:28    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
What's with everyone bashing the wide tires?
The difference is minimal (in terms of performance).
It looks better that way.
What's the point of having 170 horsepower with 195 tires in the end?
In the end, everything needs to be right and well-coordinated.
Based on my experience, I have to say it's a good chip.
Ultimately, it's better to have professionals handle it, as the risk of something breaking is simply too high.
Translated on 12-10-2026, 13:17.
fr
Karma: +0 / -3   Thank you, like it!
Post15-07-2006, 14:41    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
Tuning Pump-Nozzle units PD 520 available here in the shop - 699.00 EUR icon_razz.gif.
So much more expensive than the good old VP nozzles...
Translated on 12-10-2026, 13:18.
Post15-07-2006, 17:07    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
You won't believe this: Best top speed with the lowest fuel consumption icon_mrgreen.gif.
im-111
Post16-07-2006, 10:31    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
I believe it...
What's the point of having a fuel consumption of 5-6 liters, and every time you take a turn, you feel like you're in a carriage pulled by 170 horses?
But, as I said, the entire package needs to be right.
Translated on 12-10-2026, 13:19.
Post16-07-2006, 12:04    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
If the carriage then overtakes you from the outside in the curve during heavy rain, you know why... icon_smile.gif
P.S.: Wide tires are not a guarantee of good road handling or high cornering speeds. I've often experienced that racing vehicles with narrower tires (of the same compound) were significantly faster than those with wider tires.
fr wrote:
Tuning Pump-Nozzle units PD 520 available here in our shop - €699.00.
If you buy the pump from VP as well, then the situation changes again. In that case, VP tuning is clearly at a disadvantage.
Translated on 12-10-2026, 13:20.
Post16-07-2006, 14:10    Subject: PD Engine Tuning: 10 or 20 Cent Upgrade Quote
a guarantee of good road handling or high cornering speeds. I've often experienced that racing vehicles with narrower tires (of the same compound) were significantly faster than those with wider tires.icon_wink.gif
Even those with 70% of the total weight on the front axle }?
Translated on 12-10-2026, 13:22.
No new posts 10Cent Tuning Technical Articles
No new posts Tuning: Intake & Intercooler - Optimization Guide Technical Articles
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts Power-up delay for a 10-cent tuning Diesel Engine Technology
No new posts TDI Tuning: 10 Cent Upgrade & Benefits Diesel Engine Technology
No new posts @Ulf Topic: Chip tuning and 10-cent optimization Diesel Engine Technology
No new posts Pump Nozzle Tuning: Cheap DIY Guide & Tips Diesel Engine Technology
