Worn clutch disc pressure plate bearing, Golf/Bora 85KW (Solution)
Michael II
Post10-10-2002, 11:25    Subject: Worn clutch disc pressure plate bearing, Golf/Bora 85KW Quote
Golf/Bora 1.9L; 85 kW TD-PD 4-Motion.
Hub worn out in the clutch disc.
Cause:
Torque transmission from the engine to the gearbox. The external teeth of the hub on the clutch disc are completely worn out.
Such damage typically occurs after a short period of operation and only in conjunction with a significantly increased misalignment between the engine and the transmission.
Instead of a cable holder designed for 4-Motion vehicles, a cable holder intended for front-wheel-drive vehicles might be installed, which can cause complications during transmission installation.
Procedure:
Before installing the transmission, check the area around the engine.
attached cable holders. If a twist is detected, the part must be replaced with part number 06A 971 845 L.
Tschüss
Michael II
Translated on 05-07-2026, 12:39.
Ratings - Worn clutch disc pressure plate bearing, Golf/Bora 85KW
No new posts Golf, Bora (from 05.00) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery drain troubleshooting for Golf IV and Bora Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Combination instrument, Golf, Bora, 05.99 to 04.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Koni Suspension Installation VW Bora 85KW TDI Transmission, Chassis, Body & Interior
No new posts Golf 4 TDI Front Noise - 85KW Transmission, Chassis, Body & Interior
No new posts MSTG: Compatible with Golf, Bora, Octavia, A3? On-Board Diagnostics (OBD)
No new posts Clutch disc lining thickness Diesel Engine Technology
