Turbo hose burst - oil in the air
kossmann
2016 Audi Q3
Post20-07-2006, 18:13    Subject: Turbo hose burst - oil in the air Quote
1.9 TDI (1Z)
Hello everyone,
"The thick rubber hose on the intake manifold (before the EGR valve) has burst, and the engine cover is full of oil. From this, I suspect that there's oil in the turbocharger air intake. Is this normal? If not, where could it be coming from?"
The car is currently emitting a lot of smoke, and in my opinion, it's not delivering its full power. This could also be because I bought a motorcycle with a 98 horsepower engine, which naturally has completely different acceleration characteristics icon_wink.gif.
Translated on 21-07-2026, 16:08.
BM
Avatar-BM
Post21-07-2006, 16:19    Subject: Turbo hose burst - oil in the air Quote
Where does this come from?
The car is currently emitting a lot of smoke and, in my opinion, doesn't have its full power, but that could also be because I bought it with a 98 horsepower motorcycle, which naturally has completely different acceleration values icon_wink.gif
Perhaps you should have bought one with 27 horsepower instead, because the difference isn't that significant then.
"Tip:"
Use the search function!
3B5 AJM
Translated on 21-07-2026, 16:10.
kossmann
2016 Audi Q3
Post21-07-2006, 16:35    Subject: Turbo hose burst - oil in the air Quote
BM wrote:
I would say it's coming from the engine
icon_rolleyes.gif Thank you!
It's definitely not normal, right?
I already figured that out myself, but searching for terms like "turbo," "turbocharger," or "oil" wouldn't be very helpful.
Translated on 21-07-2026, 16:11.
Denkste
Post21-07-2006, 19:43    Subject: Turbo hose burst - oil in the air Quote
Search for 'crankcase ventilation' icon_wink.gif. It is normal to have a slight oil mist in the intake system icon_exclaim.gif.
I would quickly replace the intercooler hose! Otherwise, your turbo will constantly spin faster to build up the pressure it's losing due to the crack... The fact that it's producing soot is also normal, as there isn't enough air getting through.
Translated on 21-07-2026, 16:12.
Dj Ninja
Karma: +1 / -1   Thank you, like it!
Post21-07-2006, 20:59    Subject: Turbo hose burst - oil in the air Quote
It's perfectly normal for him to see black smoke coming from the defective hose. The mass airflow sensor measures the air *before* the turbo – that is, the air entering the turbo, not the air actually consumed by the engine. However, the engine control unit regulates the fuel injection based on the measured amount of air. If half of the air being drawn in (and measured) escapes through the hole instead of properly entering the engine, then logically, far too little air reaches the engine to completely burn the injected diesel fuel. The consequence: it will get dark behind you.
Translated on 21-07-2026, 16:13.
No new posts Windshield Crack: Documentary of a 1-Year Old Car Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tuareg Door Lock: Broken Armrest Release Handle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken AAZ Timing Belt: Causes & Repair Diesel Engine Technology
No new posts AI Breakthrough: No Guarantee Transmission, Chassis, Body & Interior
No new posts Timing belt broken: Causes and repair Diesel Engine Technology
No new posts AFN Engine Damage: Piston 4 Cracked - What Now? Diesel Engine Technology
