Pulley Service: Audi A4 66/81 kW (Solution)
Michael II
Post10-10-2002, 16:44    Subject: Pulley Service: Audi A4 66/81 kW Quote
Audi A4, 66/81 kW TDI, pulley for generator, freewheel.
Affected vehicle identification numbers:
WAU ZZZ 8D Z SA 000 335 to WAU ZZZ 8D Z SA 151 550.
WAU ZZZ 8D Z TA 000 134 to WAU ZZZ 8D Z TA 330 651.
WAU ZZZ 8D Z VA 000 113 to WAU ZZZ 8D Z VA 294 233.
WAU ZZZ 8D Z WA 000 138 to WAU ZZZ 8D Z WA 237 097.
Cause:
In certain Audi A4 vehicles equipped with a 66 kW or 81 kW TDI engine and an automatic transmission, there is a possibility that irregularities in the belt drive system may lead to the failure of the belt tensioner.
Procedure:
The rigid pulley on the generator should be replaced with a pulley that has a freewheel mechanism.
At the same time, the belt tensioner and the ribbed belt need to be replaced.
Important:
Active customer outreach is not performed.
Parts per vehicle (depending on the generator model).
Conversion kit for BOSCH generator, 1 x parts set 028 998 998 A, or...
Conversion kit for VALEO alternator, 1 x parts kit 028 998 998 B.
Tschüss
Michael II
Translated on 12-10-2026, 9:33.
Ratings - Pulley Service: Audi A4 66/81 kW
No new posts Workshop Action: Clamp for Steering Column, A4 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Door Hinge Bolt Repair: Audi A4 Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop action: Wiring at front seats, A3 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Loosen pulley/vibration damper? Diesel Engine Technology
No new posts Torque Specs: Pulley & Seal for 1Z Engine Diesel Engine Technology
No new posts GTI TDI Timing Belt Pulley Issue: Broken on KW? Diesel Engine Technology
No new posts Audi 8E Recall: Action 75 B2 Fix Transmission, Chassis, Body & Interior
