Engine control unit destroyed during start-up
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Pegaso3
Post16-08-2006, 21:13    Subject: Engine control unit destroyed during start-up Quote
Hello, I have a Passat 35i, manufactured in 1990, with a 1.8l PF engine and a manual transmission. Recently, to my surprise, the engine suddenly stopped starting. An inspection revealed that the fuel injection valves are completely connected to ground, and the engine is completely dead. A used engine control unit (ECU) initially made the engine run again. However, after 4 days, the same problem occurred again. Now I have installed the third ECU, and I am constantly worried that it will be destroyed again. An electrical inspection of the fuel injection system did not reveal any errors. The ground points are in order, and the regulator voltage is OK. Perhaps someone has already experienced this problem and can give me a tip. By the way, the engine was running perfectly. The control unit will definitely be destroyed when the engine starts.
No new posts Doku Lupo 6X1 MJ 2002, Engine will not start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts a6 avant v6 tdi, bj. 6/98 beim starten morgens auf nur 4 zyl Diesel Engine Technology
No new posts Problems starting, the fault lies with the ignition switc... Diesel Engine Technology
No new posts Verbrauch steigt, Weisse Wolke beim starten, keine Leistung Diesel Engine Technology
No new posts Steuergerät wird nicht mehr erkannt Diesel Engine Technology
