LMM failure on Ibiza TDI AFN (81kW)?
MONCHI
Post11-10-2002, 14:40    Subject: LMM failure on Ibiza TDI AFN (81kW)? Quote
I'm having the following problem:
My car has significantly more power when it's cold, and it doesn't really start performing well until around 3000 RPM. I have a power box from KW-Systems installed, and the potentiometer is turned all the way up. I called them about it, and they told me that my mass airflow sensor (MAF) might be defective.
How can I check that?
Thank you for your help!
Monchi.
Michael II
Post11-10-2002, 15:07    Subject: LMM failure on Ibiza TDI AFN (81kW)? Quote
First, I would read the error codes. If there is no information provided, you should perform a measurement run (values are in the error database).
The topic of LMM has already been discussed quite frequently here. Just search for it...
Tschüss
Michael II
No new posts Workshop action: Free-running disc, Sharan 81kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 81KW - Kupplung rutscht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM Failure: Ibiza Diagnostic Trouble Code (DTC) Log On-Board Diagnostics (OBD)
No new posts Glow plug behavior in a Golf III TDI 81kW engine On-Board Diagnostics (OBD)
No new posts G62 at the ASZ in the Seat Ibiza Diesel Engine Technology
No new posts OBD tuning for the Ibiza ASZ Diesel Engine Technology
