Climatronic LabelFile: Download & Info
Post25-07-2006, 9:39    Subject: Climatronic LabelFile: Download & Info Quote
The control unit in the Leon seems to have its own part number (it also identifies itself as a 1M-Climatronic), and my label file doesn't contain any useful information.
Does anyone have one (maybe even from a G4), so I can see what those 23751 temperature values mean?
Thank you.
Translated on 07-10-2026, 2:03.
Post25-07-2006, 9:48    Subject: Climatronic LabelFile: Download & Info Quote
Hi Martin,
The complete VAG part number would be very helpful here.
Translated on 07-10-2026, 2:04.
Post25-07-2006, 9:57    Subject: Climatronic LabelFile: Download & Info Quote
Damn icon_smile.gif.
I thought so.
To do that, I first have to go to the parking garage during my lunch break.
Post25-07-2006, 12:06    Subject: Climatronic LabelFile: Download & Info Quote
The plastic is called:
1M0 820 043 C
Thank you.
Jochen_145
Post25-07-2006, 12:14    Subject: Climatronic LabelFile: Download & Info Quote
The reason the Leon has its own 'Climatronic' system is because the Climatronic system of the G4 is connected to the Comfort-CAN.
However, the Leon does not have a Comfort-CAN system.
Therefore, the climate control system also uses speed and engine speed signals.
Therefore, I don't believe that the label file from G4 is suitable.
Best regards, Jochen.
Translated on 07-10-2026, 2:05.
Ross-Tech-Support
Post25-07-2006, 12:32    Subject: Climatronic LabelFile: Download & Info Quote
Jochen_145 wrote:
The reason the Leon has a "separate Climatronic" system is because the G4's Climatronic is connected to the Comfort-CAN.
It's simply because the design, and therefore the fit, of the front is different. icon_cool.gif
Jochen_145 wrote:
Therefore, I don't believe that the label file from G4 is compatible.
"No offense, but the correct saying is 'Knowledge is power,' not 'Belief is power.' icon_twisted.gif
Basically, the 1J/3B label is suitable, although the MWB codes 009/010/011/013 are not yet covered. Assuming you (Martin) are using an up-to-date VAG-COM version, please proceed as follows:
VAG-COM > Applications > Control Unit Image.
Address: 08
Function: Measurement data blocks.
Format: Label template.
Start
After that, you will find the file 08-1M0-820-043-C.PLB in the directory /VAG-COM/Logs/, and you should then send it to me via email. icon_wink.gif
Translated on 07-10-2026, 2:07.
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts BLS Label File: Guide & Download On-Board Diagnostics (OBD)
No new posts Fuel injectors for 130 PD? Diesel Engine Technology
No new posts Pierburg MAF Adapter Plugs Diesel Engine Technology
No new posts Sensor technology for oil temperature Diesel Engine Technology
