Change MFA Display Order Levels
Kruegerjean
Post02-08-2006, 18:18    Subject: Change MFA Display Order Levels Quote
In the multi-function display (MFA) of my Audi A4 8E, after turning on the ignition in the first level, the values from the navigation system are displayed. This also happens even when the navigation is turned off (displaying only the direction indicator).
When the switch is activated, MFA is enabled, followed by the two levels of BC.
Is it possible to change the order so that the bike computer is displayed first in the normal view?
Unfortunately, I couldn't find anything about that in the manual, or perhaps I missed it.
Jean.
Translated on 15-08-2026, 18:30.
No new posts Spark plug firing order Technical Data
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Rear brake caliper, sequence Transmission, Chassis, Body & Interior
No new posts Error: Incorrect Request Order - Fix Now! Diesel Engine Technology
No new posts Automatic Shift Software: Change or Fix? Diesel Engine Technology
No new posts Adjust idle speed On-Board Diagnostics (OBD)
