AGR/VTG Solenoid Valve Replacement
fgolf
Post20-07-2006, 11:43    Subject: AGR/VTG Solenoid Valve Replacement Quote
I removed the magnetic valves for the EGR system and the VTG adjustment while changing the vacuum hoses, and I may have mixed them up. icon_confused.gif
Is there a simple way to identify which valve is for the AGR (Abgasrückführung) and which is for the VTG (Variable Turbine Geometry)?
The design looks identical, and both are made by Pierburg.
One valve has a gray head (in/out connections), while the other has a black head.
Both have the designation 1HO 906 627 on the back.
One has the identification number 7.21903.20 on the back, while the other has the identification number 7.21903.25 on the back.
It's a 1999 Volkswagen Golf 4 TDI with an ALH engine.
Thank you in advance for your answers.
Translated on 11-09-2026, 4:40.
Post20-07-2006, 11:48    Subject: EGR & VTG Solenoid Valve: Swapping Guide Quote
According to my knowledge, the Grau Kopf part should still have an "A" after the part number, and that one is for the VTG.
Black = AGR.
Translated on 11-09-2026, 4:42.
myfisch
Post06-08-2006, 9:15    Subject: AGR/VTG Solenoid Valve Replacement Quote
What is the exact difference between the two valves?
Are there other membrane or reed thicknesses for the throttle cross-section?
Post06-08-2006, 9:36    Subject: AGR/VTG Solenoid Valve Replacement Quote
Alternative membrane or spring thickness throttle cross-sections?
At least in the flow cross-sections, I was able to clearly determine this when I compared the flow rates of the VTG and AGR valves on a G3 AFN engine.
Whether the magnetic side and the spring might be different -> icon_question.gif icon_question.gif
Translated on 11-09-2026, 4:43.
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0046 - Turbocharger Boost Control Circuit Malfunction, M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Common Rail Lines: Don't Mix 2.7L & 3.0L V6 TDI Diesel Engine Technology
No new posts Magnetic valve for charging pressure regulation Diesel Engine Technology
No new posts Boost Control Valve: Limit Charge Pressure Diesel Engine Technology
No new posts Magnet Valve Part Number: EGR Diesel Engine Technology
