Summer Light Bulbs: Limited Stock!
Golfdriver
Post13-10-2002, 16:14    Subject: Summer Light Bulbs: Limited Stock! Quote
I'm having the following problem:
The alarm that usually sounds when you forget to turn off the light is suddenly broken on my device!
How can I determine what is broken?
Is there a separate fuse for that?
Or do I need to have it done at a VAG workshop?
Hello.
Translated on 21-08-2026, 5:48.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post13-10-2002, 17:40    Subject: Summer Light Bulbs: Limited Stock! Quote
Hi!
The workshop (or you, using VAGcom) can directly access the buzzer via diagnostics and thus determine whether it is the cause of the problem or not. If it is the buzzer, the workshop will naturally only replace the entire instrument cluster (as it is housed within it in many newer vehicle models), not individual components. In that case, you would have to do it yourself.
To my knowledge, there were also vehicles where the buzzer was located in the relay box – please correct me if I'm wrong. As far as I know, this type of buzzer could not be diagnosed.
Good luck!
Dirk.
Translated on 21-08-2026, 5:50.
Michael II
Post13-10-2002, 17:59    Subject: Summer Light Bulbs: Limited Stock! Quote
Which car and which model year are you referring to?
Before replacing the instrument cluster, it's a good idea to first check the wiring and switches.
Tschüss
Michael II
Translated on 21-08-2026, 5:51.
Golfdriver
Post13-10-2002, 18:52    Subject: Summer Light Bulbs: Limited Stock! Quote
Volkswagen Golf 3 Variant TDI, manufactured in August 1995.
schnupfi
Post14-10-2002, 10:39    Subject: Door Sensor Connector Quote
Take a look at the Ethernet connector pins; they seem to be loose.
Greetings.
Sneezy.
Translated on 21-08-2026, 5:52.
micha_passat
Post15-10-2002, 21:24    Subject: Summer Light Bulbs: Limited Stock! Quote
It's possible that the entire instrument cluster has loose connections!
I had one where several contacts were only lightly touched by solder, and therefore eventually reported errors. icon_sad.gif
It started with the coolant and then progressed to the battery diode. icon_idea.gif
I then resoldered several connections, and now everything is working again...
Best regards.
'Micha' translates to 'Michael' in English.
Translated on 21-08-2026, 5:53.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Light warning buzzer no longer works after renovation KI Transmission, Chassis, Body & Interior
No new posts Summer Light: Capturing the Perfect Glow Transmission, Chassis, Body & Interior
No new posts Door Won't Open? Get Help Now! Transmission, Chassis, Body & Interior
No new posts Driver's door won't open Transmission, Chassis, Body & Interior
