Zimbo30
Joined: 08/16/2006 Posts: 13 Karma: +0 / -0 Location: Horb am Neckar
17-08-2006, 20:26 Subject: GRA Not Working Passat 3B 1999 |
I have purchased a retrofit kit for my Passat 3B 1.9 TDI, manufactured in March 1999.
"I just installed it, and it's brand new. I've done this before on a Passat 3BG from 2002 without any problems. But today, it didn't work. I was surprised that the light didn't come on when I activated the GRA (automatic high beam). Does the Passat even have a control light for this in the instrument cluster? I activated it with VAG COM, but it's not working. I checked the error memory, but there are no errors. Does anyone have any ideas? I'm 100% sure I connected the cables correctly."
Best regards, Dirk.
Translated on 29-10-2026, 18:09.
Joined: 04/12/2002 Posts: 18139 Karma: +805 / -0 Location: St.Gallen 2018 Volkswagen T6
17-08-2006, 20:53 Subject: GRA Not Working Passat 3B 1999 |
Check the switch bits using the diagnostic function and see if GRA (Gearbox Ratio Adaptation) is active (this can be seen in the control unit information in VAG-COM).
Translated on 29-10-2026, 18:10.
Profile PM WWW Garage |
R.M. Schrauber
Joined: 06/15/2004 Posts: 389 Karma: +14 / -0 Location: DD
17-08-2006, 21:07 Subject: GRA Not Working Passat 3B 1999 |
Hello.
My 1998 Passat doesn't have a GRA light in the instrument cluster (GRA was added later), while my father's 2000 Golf does (GRA was original). You can easily see it when the GRA is not active. So, it's likely that your instrument cluster doesn't have a light.
Best regards!
Translated on 29-10-2026, 18:11.
Zimbo30
17-08-2006, 22:22 Subject: GRA Not Working Passat 3B 1999 |
Thanks for your replies. Are you asking if the GRA (Graphics Rendering Accelerator) is enabled? You can tell if it's enabled by the "G" indicator, but is there a way to check if it's currently active?
Translated on 29-10-2026, 18:12.
Russpartikel
17-08-2006, 22:39 Subject: GRA Not Working Passat 3B 1999 |
Hi Zimbo30,
As Rainer already mentioned: "Check switch bits via diagnostics."
Rp
P.S. In the diagnosis, it is possible to test the individual "switch functions." Golf IV Variant MY2000, MKB AGR, Lader, Abgasanlage u. Getriebe EFF vom ARL, MSG Soft ASV+Chip, 0.216 Düsen, Kraftstoffkühler.
mullemaus Guest
18-08-2006, 0:55 Subject: GRA Not Working Passat 3B 1999 |
Does the Passat even have a control light in the instrument cluster? I've enabled it with VAG COM, but it's not working.
The lamp turns on at a specific software version (year/part number/hardware version of the control unit). If you were to install a control unit from 2002, it would
Subject: Vag-Com and GRA, please unlock them again, including turning the ignition on/off to confirm. Then, a test drive. If it still doesn't work, repeat the process. We just had another case where it only worked after the 3rd attempt. The exact reason for this is still unknown  .
Translated on 29-10-2026, 18:13.
Herr Antje Schrauber
Joined: 01/18/2006 Posts: 1547 Karma: +7 / -0 Location: Nahe Tübingen
18-08-2006, 5:37 Subject: GRA Not Working Passat 3B 1999 |
Zimbo30 wrote: | | Does the Passat even have a warning light in the instrument cluster? |
Mine is a 01/2001 model. Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 29-10-2026, 18:14.
Holger247 Schrauber
Joined: 11/05/2002 Posts: 259 Karma: +0 / -0 Location: Böblingen
18-08-2006, 9:52 Subject: GRA Not Working Passat 3B 1999 |
Is it just the light that's not working for you, or is the cruise control malfunctioning?
The lamp might not be installed (it wasn't in my Golf IV from 1998 either).
If the cruise control is not working correctly while driving, check the bits using VAG-Com (each switch position can then be read).
I recently had a speed limiter installed (through a VW service action), and the lever was defective (a contact was loose), which could be seen in the VAGCom diagnostic tool. Now I understand why those levers were being offered for sale...
But VW exchanged it for free.  --------------------------------------------
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 29-10-2026, 18:15.
Zimbo30
18-08-2006, 20:09 Subject: GRA Not Working Passat 3B 1999 |
Nothing is working. Neither the lamp nor the GRA. Where can I read the bits in VAG COM? I've already tried to find something, but without success?
Best regards, Dirk.
Translated on 29-10-2026, 18:16.
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
18-08-2006, 22:29 Subject: GRA Not Working Passat 3B 1999 |
Quote: | | Does the Passat even have a warning light in the instrument cluster? |
Not for the 1999 model year. 3B5 AJM
Translated on 29-10-2026, 18:17.
Holger247 Schrauber
22-08-2006, 9:21 Subject: GRA Not Working Passat 3B 1999 |
Zimbo30:
Quote: | Where can I read the bits in VAG COM? I've already tried to find something, but without success??
We have a very useful feature in this forum: the search function.
"Cruise control installation problems" "Cruise control" "GRA" "GRA problem" etc.
=> there are many results.
Try using measurement group 6. --------------------------------------------
GIV - 98 - ALH
Touran 5T 2.0 TDI
