tomsyncro Blaumann
19-08-2006, 20:59 Subject: Diesel Filter Replacement VW T5 ACX |
Hello.
I have a question regarding the replacement of the T5 diesel filter. The filter has 4 connections, and I've never...
I bought such an expensive filter for 80€. Do I need to fill the filter with diesel, or is that not necessary?
Does turning the ignition on fill the pump?
Vehicle: VW T5, manufactured in September 2003, model ACX, 1.9L engine, 63 kW.
Best regards, Tom.
Translated on 26-08-2026, 23:44.
bastion Blaumann
19-08-2006, 23:08 Subject: Diesel Filter Replacement VW T5 ACX |
I believe the pump is only briefly activated by the ignition. If you have a VAG-Com, you can use it to bleed the system, which is easier.
A4 Avant 08/01 AWX 05/08-
Translated on 26-08-2026, 23:45.
tomsyncro Blaumann
23-08-2006, 18:57 Subject: Diesel Filter Replacement VW T5 ACX |
Hello.
Today I performed the service on the T5 and filled the diesel filter with diesel.
It started right up, and it's running perfectly again.
Thank you again for your reply.
Best regards, Tom.
