Audi A3 Software Update: Check & Download
Go to page: 1, 2, 3  Next
rosinj
Post26-04-2006, 14:33    Subject: Audi A3 Software Update: Check & Download Quote
Hello everyone,
We have an A3 2.0 TDI with a DSG transmission, manufactured on May 14, 2004.
Okay, here's the problem. What's the status of the software? I've read a lot in the forum about the idling roughness.
Now I'm not sure if I'm affected by this issue. Sometimes the car jerks, and sometimes it doesn't. Maybe someone here can help me and also explain how to read the software version (i.e., the number).
Here's what the log is showing for me:
03G906016 DT => Engine Control Unit? Or what?!
5878 => Softwarestand? Or what?!
A friend has the same engine control unit (ECU) part number, but a different software version number: 6179?
Who can help me with this?
Certainly, I'd be happy to help. Please provide the text you would like me to translate from German to English.
Jürgen.
Translated on 31-10-2026, 5:07.
Post26-04-2006, 14:43    Subject: Audi A3 Software Update: Check & Download Quote
Hello Jürgen,
Yes, the data looks like you suspected. Unfortunately, I also don't have any ideas about the actual problem; it feels like one of the cylinders isn't injecting fuel intermittently.
Translated on 31-10-2026, 5:09.
vagtuning
Post26-04-2006, 17:53    Subject: Audi A3 Software Update: Check & Download Quote
However, the information is somewhat outdated. The most current data for your engine control unit (ECU) is version 7000.
bastion
Karma: +6 / -1   Thank you, like it!
Post27-04-2006, 7:01    Subject: Audi A3 Software Update: Check & Download Quote
Where can you actually obtain new data sets? Can they be installed using VAG-COM, or do you need different equipment for that?
Post27-04-2006, 7:22    Subject: Audi A3 Software Update: Check & Download Quote
Hi.
bastion wrote:
Where does one actually obtain new data sets? Can these be installed using VAG-COM, or does one need different equipment for that?
VAG-COM can do a lot, but it's not a tool for flashing the engine control unit (ECU). Either you get lucky and a tuner already has your original software version and can flash it into your ECU, or you go to a VAG dealership.
Translated on 31-10-2026, 5:10.
rosinj
Post27-04-2006, 7:41    Subject: Audi A3 Software Update: Check & Download Quote
@VAGTUNING: What are the differences between the individual datasets? Are these differences listed anywhere? And why are things constantly being changed?
Jürgen.
Translated on 31-10-2026, 5:11.
Post27-04-2006, 7:53    Subject: Audi A3 Software Update: Check & Download Quote
... why are there constantly new versions of Windows and Word?
Customers are noticing something. The manufacturer themselves only start to realize something after a long time (with production cars from the factory that accumulate kilometers on the odometer as quickly as possible).
And then it will be improved...
Translated on 31-10-2026, 5:12.
rosinj
Post27-04-2006, 9:10    Subject: Audi A3 Software Update: Check & Download Quote
Yes, but I would like to know what changes are being made and whether it makes sense to install the updates. It's not always a good idea to install updates for Word and Windows either.
Is there a comprehensive overview of this available anywhere?
Ross-Tech-Support
Post27-04-2006, 9:29    Subject: Audi A3 Software Update: Check & Download Quote
To put it simply, yes, the update is worth it and may also fix the idle shaking. icon_rolleyes.gif
Translated on 31-10-2026, 5:13.
Post27-04-2006, 10:47    Subject: Audi A3 Software Update: Check & Download Quote
The car with the VIN 03G906016GN 7420 also exhibits the idle problem, even though the car is relatively new.
I wouldn't completely rule out the mechanics...
vagtuning
Post27-04-2006, 12:40    Subject: Audi A3 Software Update: Check & Download Quote
Rainer - the data you're referring to is likely from an A4 BLB, if I'm not mistaken. The A3 version would have a BKD engine paired with a DSG transmission.
Question: Has it ever happened to you that the car stalled when shifting from Reverse (R) to Drive (D)? (If it's a DSG transmission?)
Translated on 31-10-2026, 5:14.
rosinj
Post27-04-2006, 13:01    Subject: Audi A3 Software Update: Check & Download Quote
@vagtuning:
Not yet. I've only recently started having problems with the engine not starting easily in the mornings when it's cold. It doesn't matter if it's below freezing or not. It starts, sputters a bit, and then dies. Then you have to crank it for 3-5 seconds, and then it runs. Or sometimes it will start, I'll put it in drive and try to move, and then it dies.
That's how it is.
Where can I find information about what changes were made in each version? It should be accessible to the average user like me.
"Thank you."
Translated on 31-10-2026, 5:15.
Post27-04-2006, 13:04    Subject: Audi A3 Software Update: Check & Download Quote
No, it wasn't a DSG (direct-shift gearbox), but a manual transmission. My comment only referred to the idling problem, which VAG (Volkswagen Group) really needs to fix. The car was practically new, and since May 2004, one would expect it to be running smoothly by now.
Translated on 31-10-2026, 5:16.
tdi pumpe düse
Post27-04-2006, 14:50    Subject: Audi A3 Software Update: Check & Download Quote
hello everyone,
Check the sealing rings of the PDE (common rail pressure enhancement) injectors and inspect the tandem pump. I once wrote an article about how to check these components, but I can't seem to find it anymore.
Best regards.
Translated on 31-10-2026, 5:17.
vagtuning
Post27-04-2006, 17:31    Subject: Audi A3 Software Update: Check & Download Quote
Not yet. I've only recently started having problems when the engine is cold in the morning. It doesn't matter if it's below freezing or not. It starts, sputters a bit, and then dies. Then you have to crank it for 3-5 seconds, and then it runs. Or sometimes it starts, tries to go into gear and accelerate, and then dies.
Thank you.
Then, have the dealer install the new version for you.
Then at least the 'hanging' problem should be gone - in older versions (like yours), the AGR rate is incorrectly adjusted, which has been corrected in the newer versions.
Chrisi.
Translated on 31-10-2026, 5:18.
rosinj
Post28-04-2006, 9:50    Subject: Audi A3 Software Update: Check & Download Quote
@vagtuning:
What does the EGR rate have to do with the exhaust temperature? When the engine is cold, cooled EGR is not recirculated. And shortly after starting, I don't have any uncooled EGR available yet, because the air needs a moment to heat up.
Can you perhaps explain that in more detail?
And once again, the question: where can I find an overview showing what changes were made in each software version?
Translated on 31-10-2026, 5:19.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Software Version: MSG Part Number Lookup On-Board Diagnostics (OBD)
No new posts Software Version 038 906 012 AT - Change Diesel Engine Technology
No new posts MSG 038 Software: Update Available? On-Board Diagnostics (OBD)
No new posts ECU Software Version: Read & Check Now On-Board Diagnostics (OBD)
