Tiptronic A6: Gap Between Gears - Problem?
michael_kaeppler
Post12-09-2006, 18:22    Subject: Tiptronic A6: Gap Between Gears - Problem? Quote
My father drives an A6 2.5 TDI quattro (4B) with a 5-speed tiptronic transmission, which I believe was manufactured in 2004. (He bought it used.)
Between the second and third gear, there's a kind of gap. That is, the display (when Tiptronic is activated) already shows gear three, even though there's no power transmission, and the engine initially runs 500 rpm higher, as if the clutch is slipping, before the gear "engages" after 2-3 seconds and is actually in place.
This issue occurs both when upshifting and downshifting, in both Tiptronic and normal mode. It behaves like an extra gear.
The error memory is empty.
After consulting with Audi, the mechanic first changed and topped up the transmission fluid (apparently, there wasn't enough in it) and said I should drive it for 1000 km. If it doesn't improve, they will replace the transmission (under warranty). Seriously? The problem is still the same, and then they want to replace the transmission? I doubt it's a mechanical problem; it's probably an electronic issue, like so often. Does anyone have any ideas?
edit: Is there a way to adjust the clutch engagement point, or is it possible to perform a basic adjustment of the gearbox?
Michael.
Translated on 18-09-2026, 12:07.
Herr Antje
Post13-09-2006, 8:19    Subject: Audi A6 Tiptronic: Gear Shift Problem? Quote
michael_kaeppler wrote:
If it weren't for the fact that it might be better, you would replace the transmission (under warranty). Lol, the problem is unchanged, and then you replace the transmission?
Okay, I would be happy to get a new transmission for free. If it turns out that wasn't the problem, then they would still have to fix the actual issue.
Perhaps someone here knows something, I unfortunately don't. This possible solution, written by experts, was only mentioned to me by the dealer after the gearbox replacement icon_cool.gif.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 18-09-2026, 12:09.
michael_kaeppler
Post14-09-2006, 13:03    Subject: Tiptronic A6: Gap Between Gears - Problem? Quote
Okay, something different: Does anyone have a label file for the automatic transmission, or can someone tell me what the meaning of the data blocks is?
Translated on 18-09-2026, 12:10.
Nebelwerfer_TDI
Post14-09-2006, 13:16    Subject: Tiptronic A6: Gap Between Gears - Problem? Quote
Unfortunately, I don't have a label file right now, but if they offer you a new transmission under warranty, then go for it icon_exclaim.gif. Even if the problem isn't fixed with it, you'll have a transmission that is considerably younger and less likely to break down than an older one.
If that wasn't it, then they can definitely exchange it icon_lol.gif.
Translated on 18-09-2026, 12:11.
Troubleshooter
Post14-09-2006, 13:21    Subject: Tiptronic A6: Gap Between Gears - Problem? Quote
Something different: Does anyone have a label file for the automatic transmission, or can someone tell me the meaning of the data blocks?
What does your gearbox say?
And what software do you want to use to edit the dataset?
Matthias.
michael_kaeppler
Post14-09-2006, 15:38    Subject: Tiptronic A6: Gap Between Gears - Problem? Quote
@everyone: Of course, it's great to have the transmission replaced under warranty, but I'm more interested in knowing what's actually wrong with it...
@Troubleshooter: I don't have the part number of the control unit memorized; I'll need to extract it from VAG-COM. What do you mean by "edit the data set"? I simply want to analyze the switching processes using a log file, and I'd like to know the meaning of the measurement blocks.
Translated on 18-09-2026, 12:12.
michael_kaeppler
Post15-09-2006, 23:08    Subject: Tiptronic A6: Gap Between Gears - Problem? Quote
The part number is 4B0 927 156 FK AG5 01V 2.5l TDI RdW 2222.
I have now identified the measurement groups, as the same control unit is also used in the Phaeton, for which a label file is available.
I would like to know what basic settings can be configured on this control unit.
Michael.
Translated on 18-09-2026, 12:13.
No new posts Doku Golf 1J, Schleifgeräusche in allen Gängen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vibration/Humming Noise 1500-1900 RPM Diesel Engine Technology
No new posts tiptronic without value for soft coding ?! On-Board Diagnostics (OBD)
No new posts Doppelkupplung rutscht in geraden Gängen Transmission, Chassis, Body & Interior
No new posts Difference between the Steuergerät for AAT and AEL? Diesel Engine Technology
