Speedometer Malfunction: How to Replace It
silikon
Avatar-silikon
Post13-09-2006, 8:10    Subject: Speedometer Malfunction: How to Replace It Quote
Hi!
I have a VDO 1J5 920 826 C - IMMO III. It has a defective LCD display on the onboard computer, and the fuel gauge is malfunctioning even though the fuel sensor is working correctly.
I received a "new" kidney through an online auction, and it has the same model number.
The new tachograph unit has 0 kilometers and a 4-digit login code.
Is this enough to change the speedometer, or do I also need the 4 or 7-digit login codes from my current installed infotainment system to make the change? (Can I obtain these from my VW workshop?)
Do I still need the vehicle identification number (VIN) from the new AI system?
I read the procedure for Ki with IMMO 3 on the Ross Tech website, but I don't fully understand it.
My friend has the original Hex-Can USB interface with an integrated license.
Greetings from Slovenia!
Dieselschrauber aus Slowenien!
Meine Diesel geschichte:
1. Golf 4 TDI Highline BJ 1999 2002-2004
2. Golf 4 SDI Sydney BJ 2001 2004-2006
3. Golf 4 TDI Pacific BJ 2003 2006-2011
4. Passat 3C Comfort BJ 2009-????
Translated on 14-10-2026, 4:40.
mullemaus
Post13-09-2006, 20:08    Subject: Speedometer Repair: How to Replace a Faulty Unit Quote
Hi!
I received a 'new' kidney through an online auction, and it has the same model number.
If the Tcho is not in the new mode, you also need the login from the currently installed AI. That would be the simplest way. If the Tacho is in the new mode, the Tacho will take the data from the engine control unit during the learning process. icon_wink.gif
Translated on 14-10-2026, 4:43.
silikon
Avatar-silikon
Post14-09-2006, 8:17    Subject: Speedometer Malfunction: How to Replace It Quote
So, if the odometer reads 0 km, does that mean it's in a new mode?
Can someone please post a more detailed explanation of this procedure here?
I want to be 100% certain because I can't afford to make any mistakes in the process.
Translated on 14-10-2026, 4:44.
mullemaus
Post14-09-2006, 15:35    Subject: Speedometer Malfunction: How to Replace It Quote
So, if the odometer reads 0 km, is it in a new mode?
I want to be 100% certain because I can't afford to make any mistakes in the procedure.
The 0 KM reading has nothing to do with the 'New Mode' setting. 'New Mode' refers to the factory default settings. It is possible to read the data after connecting the speedometer.
The new AI is in a new mode when: Select 'STG' -> 'Tacho', then 'Measurement Groups' -> 'Function 08' -> 'Group 022', and the value '4' is set to '4'.
Is there a 6? icon_wink.gif No new mode.
Translated on 14-10-2026, 4:45.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Skoda dashboard/instrument cluster faulty Transmission, Chassis, Body & Interior
No new posts Audi A3 speedometer and fuel gauge malfunction Diesel Engine Technology
No new posts VW Golf 4: Replace Analog Speedometer with FIS Display Transmission, Chassis, Body & Interior
No new posts Speedometer: G3 Impulse Calibration Adjustment Diesel Engine Technology
