VNT-15 Loader: AFN vs. ALH Differences
3BVari
Karma: +1 / -1   Thank you, like it!
Post12-09-2006, 16:45    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
Hello, fellow diesel enthusiasts!
My turbocharger from my Passat 3B with the AFN engine appears to be defective.
Now I was able to acquire another turbocharger, also a VNT-15, from a Golf 4 ALH.
My question: Does this turbocharger even fit my Passat? The exhaust manifold on the (new) turbocharger is completely different, and it can't be easily removed like it is in my car.
"Also, in my case, the vacuum sensor on the VTG goes upwards, while on the other turbocharger from the Golf, it goes downwards... (I guess this is due to space constraints)."
I would be grateful for any help.
Best regards.
Translated on 16-10-2026, 5:42.
mullemaus
Post12-09-2006, 20:11    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
G4 ALH is currently a GT17 49 VA with a manifold. Are you sure it's a VNT 15 from the G model? Or is it a part from a Sharan? Do you have the part number handy? icon_wink.gif
Translated on 16-10-2026, 5:43.
3BVari
Post15-09-2006, 15:10    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
Okay, according to the model number, it's a VNT-15. Besides the turbine housing on the exhaust side and the differently installed pressure sensor, the turbochargers are identical.
Can anyone help me with this?
Best regards.
Translated on 16-10-2026, 5:44.
Post15-09-2006, 15:17    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
3BVari wrote:
Can anyone help me with that?
Perhaps. At least, if you would answer Mulle's question:
Mullemaus wrote:
Do you happen to have the part number handy?
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 16-10-2026, 5:45.
Nebelwerfer_TDI
Post19-09-2006, 9:15    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
ALH is a transversely mounted engine. The support bracket on the exhaust housing looks different (rotated 90 degrees) compared to the longitudinally mounted engine. We discussed this just a few months ago...
neubaupe
Post20-09-2006, 22:27    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
Are you sure the vacuum sensor is pointing in the 'other' direction, and not towards the compressor housing?
Best regards.
peter
Translated on 16-10-2026, 5:46.
mullemaus
Post20-09-2006, 23:01    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
Are you sure that the vacuum sensor is pointing in the 'other' direction, and not at the compressor housing?
Best regards.
peter
Golf and Co are showing a downward trend in real estate, at least the ASZ Polo today had a price decrease. I think it was a KKK, I need to check again tomorrow. icon_wink.gif
neubaupe
Post21-09-2006, 8:25    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
Okay, for the AFN (Ibiza, Seat) models, the canister should be oriented with the opening facing upwards.
Best regards.
peter
Translated on 16-10-2026, 5:47.
Nebelwerfer_TDI
Post21-09-2006, 8:32    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
Yes, AFN always pointed upwards, as far as I know. It was only later that VW was foolish enough to leave them pointing downwards, where the dirt gets in icon_twisted.gif.
Translated on 16-10-2026, 5:48.
Post21-09-2006, 8:57    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
For the sake of completeness (to avoid confusion):
2001 Ibiza ASV - Can up.
2001 Leon ASV - Can upside down.
Post21-09-2006, 9:14    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
dieselmartin wrote:
Just for the sake of completeness (and confusion).
Or also:
ALH Ibiza 6K: Upgraded.
ALH G4 (similar year of manufacture, if I recall correctly): Can facing downwards.
It could be due to the fact that, with the Ibiza, the can would collide with an engine mount (G3 base?) when positioned facing downwards.
Translated on 16-10-2026, 5:49.
Post21-09-2006, 9:30    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
It could be due to the fact that, with the Ibiza, the can would collide with an engine mount (G3 base?) when positioned downwards.
Yes, the engine mounts and:
The Ibiza directs the compressed air upwards, routing it around the engine to the LLK (located beneath the transmission).
Leon/G4 guides them downwards, then directs them to the right, through the town hall's central area, to the side entrance.
Translated on 16-10-2026, 5:50.
neubaupe
Post21-09-2006, 9:53    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
The Ibiza directs the compressed air upwards, sending it around the engine once before reaching the intercooler (located under the transmission).
I don't want to come across as a know-it-all, but regarding this...
'The design is something you have to congratulate VW/Seat (?) on. It's definitely about 1-1.5 meters [tall/long/wide].'
The intercooler route was unnecessarily created - and they call this a 'GT' :-/
Best regards.
peter
Translated on 16-10-2026, 5:51.
Nebelwerfer_TDI
Post21-09-2006, 10:00    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
I don't want to claim that I'm the overly clever know-it-all - but regarding this...
'The design is something you have to congratulate VW/Seat (?) for. It's definitely about 1-1.5 meters
For this, they have a more sensible intercooler design compared to older Ford and PSA engines. In those, the intercooler was mounted on top of the engine, and air was drawn in through a channel between the hood and the interior paneling. As far as I remember, this gap was only about 1-2 cm wide, and you can now imagine how such a design performs when going uphill with little airflow and a heavy load.
Translated on 16-10-2026, 5:53.
Post21-09-2006, 10:39    Subject: VNT-15 Loader: AFN vs. ALH Differences Quote
...and this design was something the T4 model was able to fully realize.
The T4 TDI also has an oil cooler mounted on the engine (at least the 102 hp version).
"Bastard" because everything about the T4 is different from all other VWs.
I've been taking apart VWs for over 10 years, but the T4 is always a source of frustration and seemingly impossible challenges...
Translated on 16-10-2026, 5:54.
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts AXR PD: Charger/Backup Power Issues Diesel Engine Technology
No new posts Wastegate Air Valve: VTG Turbocharger Explained Diesel Engine Technology
No new posts VTG 17 vs. VTG 15: What's the Difference? Diesel Engine Technology
No new posts Control Unit Differences On-Board Diagnostics (OBD)
