VAG-COM: No Data Despite Label File.
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Tobi12345
Post14-10-2006, 17:14    Subject: VAG-COM: No Data Despite Label File. Quote
I have VAG-COM version 607.3, and the label files are also present for the respective control modules that I am reading, however, VAG-COM always says that no label file is available.
Where is the error?
Best, Tobi.
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Translated on 10-09-2026, 18:59.
Ross-Tech-Support
Post14-10-2006, 17:19    Subject: VAG-COM: No Data Despite Label File. Quote
[Options]
Set the debug level to 1.
[Accept]
[Auto-Scan]
Select vehicle.
[Start]
After that, please post the complete car scan results here.
Translated on 10-09-2026, 19:00.
Tobi12345
Post14-10-2006, 17:29    Subject: VAG-COM: No Data Despite Label File. Quote
@ Sebastian
Do you mean setting the error log level to 1?
It currently shows 0 for me.
Ross-Tech-Support
Post14-10-2006, 17:35    Subject: VAG-COM: No Data Despite Label File. Quote
Poorly translated by DRV, but yes, that's what I mean.
Tobi12345
Post14-10-2006, 17:42    Subject: VAG-COM: No Data Despite Label File. Quote
Here's the car scan!!!
VAG-COM Version: DRV 607.3-UD
Saturday, October 14, 2006, 6:40:52 PM.
Vehicle type: 6N - Polo 1995>2002
Scan: 01 02 03 08 17 19 25 35 41 45 46 55
Chassis number: WVWZZZ6NZYY600056
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Labels: None
Part number: 045 906 019.
Component: 1.4L R3 EDC 0000SG 1040
Coding: 00003
Workshop No.: WSC 00788
"One error found:"
17978 - Engine control unit locked.
P1570 - 35-10 - - - Interrupted.
Readiness: 0 0 X X X
Address 03: Brakes Labels: None
Part Number: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Encoding: 05603
No errors found.
Address 17: Combination instrument. Labels: None.
Part Number: 6N0 920 804 M
Part: COMBINATION INSTRUMENT BOO V05
Encoding: 00132
Workshop No.: WSC 00012
No errors found.
Address 19: CAN Gateway. Labels: None.
Part number: 6N0 909 901.
Component: Gateway <-> CAN.
Encoding: 00022
Workshop No.: WSC 00000
No errors found.
Address 25: Immobilizer. Labels: None.
Part number: 6X0 953 257.
Component: IMMO 0004
Encoding: 00001
WVWZZZ6NZYY600056 VWZ1Z0Y0350324
"One error found:"
01176 - Key
07-10 - Signal too weak - Interrupted.
End.
Translated on 10-09-2026, 19:05.
Ross-Tech-Support
Post14-10-2006, 18:18    Subject: VAG-COM: No Data Despite Label File. Quote
Hmm...
Since DRV only provides files from the original English version, the only files that should be included are those for the engine control unit and the CAN gateway. Interestingly, this is not the case. In principle, label files exist for all of the above control units.
Is the subfolder /Labels/ present, or is it still named "/Labels.new"?
Are the two files, 04-01.lbl and 045-906-019-AMF.lbl, present in the subdirectory /Labels/?
Translated on 10-09-2026, 19:10.
Tobi12345
Post14-10-2006, 18:49    Subject: VAG-COM: No Data Despite Label File. Quote
The subfolder in the diagnostic tool is called "Label.OLD".
There you'll find the DRV and User folders, as well as all the labels mentioned, including the two you named.
Translated on 10-09-2026, 19:11.
Ross-Tech-Support
Post14-10-2006, 18:58    Subject: VAG-COM: No Data Despite Label File. Quote
I have no idea why the installation isn't working correctly for you, but there should be a folder named /Labels/. Please change the name of the folder Label.OLD to Labels, and then run the same auto-scan again, also with the debug level set to 1.
Tobi12345
Post14-10-2006, 19:12    Subject: VAG-COM: No Data Despite Label File. Quote
It works!!!
"Thank you!!!!"
Whatever the reason this folder was named that, it works now.
Thank you, Sebastian.
Saturday, October 14, 2006, 8:08:25 PM.
Address 01: Engine, Labels: User\045-906-019-AMF.LBL.
Coding: 00003
"One error found:"
Address 03: Brakes Labels: 6X0-907-379.LBL
Encoding: 05603
No errors found.
Encoding: 00132
No errors found.
Labels: 6N0-909-901.LBL
Encoding: 00022
No errors found.
Encoding: 00001
"One error found:"
01176 - Key
End.
Translated on 10-09-2026, 19:16.
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Suspension Failure: Allroad Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Beetle 2004 1.4 BCA - No Label File On-Board Diagnostics (OBD)
No new posts Passat 3C - No keys available On-Board Diagnostics (OBD)
No new posts VAG Software: Great, but many questions! On-Board Diagnostics (OBD)
No new posts Brake pads are still in good condition, but the disc is w... Transmission, Chassis, Body & Interior
