w123diesel Blaumann
Joined: 11/23/2003 Posts: 55 Karma: +7 / -1 Location: Pfalz
17-06-2004, 17:15 Subject: Gear Oil: Buy Online | Best Prices |
"I've recently been experiencing a 'rumbling' noise that only occurs when turning sharply."
The service advisor at the dealership told me that the noise was coming from the differential.
Ich solle ein Getriebeölwechsel mit einem bestimmten Öl durchführen lassen,das verschafft abhilfe .So steht es auch in ihrem Maßnahmenkatalog.Das habe ich das sogar selber gelesen.In der Maßnahme stand drin Aufgrund ungünstiger Toleranzen kann es zu "Muh undBrummgeräuschen" kommen.Abhilfe:neues Getriebeöl mit der unten gen. Nummer Please provide the text you would like me to translate from German to English. I will then provide only the translation, without any explanations.
Fresh broth was added, and an immediate improvement was noticeable.
The expert said it could take up to 500 kilometers for it to completely disappear.
Okay, here's my actual question: The original transmission oil (factory fill) has the part number G052 171 A2.
The new oil has the number G052 726 A2.
Can someone tell me the exact difference?
Does the original one have a 75W90 viscosity?
What is the viscosity of the new G052 726 A2?
Best regards, Jürgen.
Translated on 19-10-2026, 8:54.
w123diesel Blaumann
17-06-2004, 17:17 Subject: Gear Oil: Buy Online | Best Prices |
What am I forgetting?
MKB ASZ
GKB ERF.
Translated on 19-10-2026, 8:56.
Cetan-Commander Guest
11-11-2004, 19:48 Subject: Gear Oil: Buy Online | Best Prices |
Hello!
And how is it today, after some time? Are the noises still gone, or have they reappeared?
CC:
w123diesel Blaumann
14-11-2004, 18:22 Subject: Gear Oil: Buy Online | Best Prices |
The noises are still gone.
"Since the replacement, my gears have been shifting very smoothly."
Otto Guest
14-11-2004, 18:48 Subject: Gear Oil: Buy Online | Best Prices |
Does anyone happen to know the difference between this and 75W90 gear oil? I recently filled this into a repaired Audi 80 transmission, and it's making unusual noises.
Translated on 19-10-2026, 8:57.
vagtuning Guest
14-11-2004, 19:41 Subject: Gear Oil: Buy Online | Best Prices |
To the person who started this thread... do you own an A3?
So, for Audi, the part number 171 A2 is for the 6-speed transmission, and the part number 726 A2 is for the 5-speed transmission.
However, I believe it should be the other way around, meaning that the 171 A2 should be used instead of the 726 A2!
WarLord Guest
14-11-2004, 20:49 Subject: Gear Oil: Buy Online | Best Prices |
What's the difference? Why does a six-speed transmission need a different type of oil?
Best regards, WarLord.
Translated on 19-10-2026, 8:58.
w123diesel Blaumann
14-11-2004, 20:53 Subject: Gear Oil: Buy Online | Best Prices |
No, I have a Golf with an ASZ engine and a 6-speed gearbox, model ERF.
vagtuning Guest
14-11-2004, 23:40 Subject: Gear Oil: Buy Online | Best Prices |
'So, it looks like it's only being replaced because the factory probably put the wrong type of oil in – the 5-speed oil.'
why it needs/gets a different oil - no idea... there's definitely a clever engineer who thought something through  .
Translated on 19-10-2026, 8:59.
15-11-2004, 14:54 Subject: Gear Oil: Buy Online | Best Prices |
The transmission oil was also replaced in my car due to rumbling and whining noises when driving with the steering wheel turned. Now, the noises are even louder and more intense than before.
CC:
15-11-2004, 16:47 Subject: Gear Oil: Buy Online | Best Prices |
Cetan-Commander wrote: | | In my case, the transmission oil was also changed due to rumbling and moaning noises when driving with the steering wheel turned. Now, the noises are even louder and more intense than before. |
Did they put a different type of oil in for you at the end, one that was different from what was originally installed?
If the noise only occurs when turning, the source of the noise is likely the differential.
Translated on 19-10-2026, 9:00.
Profile PM Garage |
15-11-2004, 18:03 Subject: Gear Oil: Buy Online | Best Prices |
Hello Ulf!
I've been wondering the same thing. Especially since VW's service department has already been involved in making this decision. I was supposed to drive 1000 km with the new oil and then possibly change it again. But the way things are looking now, I probably won't even need to drive 1000 km to realize that the new oil is bad. The noises that I complained about before are now even more noticeable.
It looks like it will probably end up being a transmission replacement  .
CC:
Translated on 19-10-2026, 9:01.
matthiasTDI96 Profi-Schrauber
15-11-2004, 18:24 Subject: Gear Oil: Buy Online | Best Prices |
Have you ever looked at all the documents from MichaelII? There was something about using two different types of oil in the ASZ transmission. I have an ERF from mid-2002 and have never had any problems. A friend has the same car with the same ERF, but from January 2002, and the transmission occasionally made slight noises and felt subjectively a bit harder to shift than mine. I then read through all the documents and somewhere I saw that there was a different oil used (I've seen and posted the number many times here). Since he put that oil in and changed it again after 1000 km (everything was done free of charge), the transmissions feel the same when shifting and are completely silent.
I'm not sure to what extent I can help you with that.
Translated on 19-10-2026, 9:02.
Devilseye503 Guest
19-10-2006, 13:53 Subject: Gear Oil: Buy Online | Best Prices |
I'm also having a problem with the ERF transmission and cornering - it makes that typical whining noise. But which oil is the right one to use?
see also the link on the left here: https://community.dieselschrauber.org/en/viewtopic.php?t=2546&highlight=getriebe%F6l+6gang
and here http://www.michaelneuhaus.de/golf/golf4maengel.htm#m
The fact is, according to the current ET-PROG data, the G 052 171 A2 is designed for the 6-speed transmission.
and G052 726 A2 is for the 5-speed.
Translated on 19-10-2026, 9:04.
Jericho Guest
19-10-2006, 16:10 Subject: Gear Oil: Buy Online | Best Prices |
Just to change the subject from the transmission for a moment: a faulty wheel bearing caused a whining and rumbling noise during cornering or when turning sharply.
Devilseye503 Guest
19-10-2006, 18:21 Subject: Gear Oil: Buy Online | Best Prices |
Don't worry - it's not the wheel bearings; they were already replaced under warranty.
'They don't last very long anymore within the VW group, but the problem really stems from this - it's been happening for 70,000 km.'
Translated on 19-10-2026, 9:05.
