Engine Not Reaching Operating Temp After 20km
moby
Post16-12-2008, 0:04    Subject: Engine Not Reaching Operating Temp After 20km Quote
Hello, I drove the same route today, as I have for years, which is 20 km long. But today, the engine didn't even warm up until I got home. When I was driving downhill, the temperature dropped from 70 to 65 degrees. The temperature was about 0.5 degrees below normal. Recently, when it was plus 5 degrees, I noticed something similar when I drove across the city and then back home, which was about 15 km. But the engine didn't even get properly warm, even though I wasn't driving defensively. What could be the cause?
cu moby
Translated on 29-09-2026, 15:42.
austrogolf
Post16-12-2008, 7:30    Subject: Engine Not Reaching Operating Temp After 20km Quote
Good morning.
That sounds like a faulty thermostat to me.
It would also be interesting to know whether the temperature is actually not being reached or maintained, or if it's simply a display error.
Greetings.
Translated on 29-09-2026, 15:43.
chris11
Karma: +3 / -1   Thank you, like it!
Post16-12-2008, 7:59    Subject: Engine Not Reaching Operating Temp After 20km Quote
Maybe that's because you're driving a diesel?
Our Galaxy system, even with the AFN and a running 3 kW auxiliary heater, struggles to maintain the temperature.
Best regards.
Christian.
Translated on 29-09-2026, 15:44.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post16-12-2008, 8:58    Subject: Engine Not Reaching Operating Temp After 20km Quote
That's why the 5 KW icon_wink.gif exists.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
BM
Avatar-BM
Post16-12-2008, 12:18    Subject: Engine Not Reaching Operating Temp After 20km Quote
As I was driving the car downhill, the temperature dropped from 70 to 65 degrees.
If the engine cools down while driving, as mentioned above, it indicates a thermostat that is no longer closing properly. The glow plugs should also be checked.
3B5 AJM
Translated on 29-09-2026, 15:45.
Post16-12-2008, 12:52    Subject: Engine slow to warm up: Troubleshooting guide Quote
moby wrote:
As I was driving downhill, the temperature dropped from 70 to 65 degrees. The temperature difference was about minus 0.5 degrees. Recently, when it was plus 5 degrees, I noticed this while driving across the city and then back home, which was about 15km. However, the engine didn't even get properly warm, even though I wasn't driving defensively. What could be the cause?
If it happens for the first time under the same driving conditions and outside temperature -> thermostat.
If it has been the same way in past winters (I always have to get used to it!), then at least nothing has changed since then icon_razz.gif.
icon_arrow.gif So, either the thermostat is always broken, or everything is okay.
Translated on 29-09-2026, 15:46.
Post16-12-2008, 15:46    Subject: Engine Not Reaching Operating Temp After 20km Quote
And I drive an ASZ without glow plug heating... well, those do exist. I'd like to agree with Ulf here.
Translated on 29-09-2026, 15:47.
moby
Post16-12-2008, 20:53    Subject: Engine Not Reaching Operating Temp After 20km Quote
Hello, can the thermostat fail when you replace the water pump? Or does it not get touched during the process? I had the timing belt and water pump replaced three weeks ago.
cu moby
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post16-12-2008, 20:59    Subject: Engine Not Reaching Operating Temp After 20km Quote
I highly doubt it, but dirt might have gotten in (or something might have come loose), right?
Translated on 29-09-2026, 15:48.
Post17-12-2008, 7:57    Subject: Engine Not Reaching Operating Temp After 20km Quote
It's not impossible, but I think it's unlikely.
Just to add some context: I also drive an ASZ, and my commute is about 25 km. This includes both country roads and highways. Initially, I drive uphill on slight inclines, but after 3 km, it's mostly downhill. The last bit is through the city. With the current temperatures, I also don't see a middle position on the combined instrument panel, but that's been the case with my Golf since it was new. The T5 warms up and maintains the temperature when the auxiliary heater is running. If the auxiliary heater is turned off, the same effect occurs.
Translated on 29-09-2026, 15:49.
BM
Avatar-BM
Post17-12-2008, 20:52    Subject: Engine Not Reaching Operating Temp After 20km Quote
Hello, as always, I drove the same route today that I have for years, a distance of 20 km. But today, the engine didn't even warm up until I got home. When I was driving downhill in the car, the temperature dropped from 70 to 65 degrees...
I think that speaks for itself.
@moby
Start the engine and let it warm up until you feel a slight amount of warm air coming from the heater. Then, check if the radiator is also warm to the touch. In this state (or until the thermostat opens at approximately 85°C), it should still be ice cold. If it is already warm, the thermostat is definitely faulty. [/quote]
3B5 AJM
Translated on 29-09-2026, 15:50.
No new posts P0011 - Camshaft Timing Delayed: Not Reached Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Gearbox: Won't Shift Gears While Driving Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS continuously regulates after sensor replacement while... On-Board Diagnostics (OBD)
No new posts Engine stalls shortly before reaching operating temperature On-Board Diagnostics (OBD)
No new posts ARL Fails to Meet Lending Target Diesel Engine Technology
No new posts Injection Volume Not Reached: Troubleshooting On-Board Diagnostics (OBD)
