A6 2.5 TDI: Fuse Location (C4)
Burki
Post20-10-2006, 6:43    Subject: A6 2.5 TDI: Fuse Location (C4) Quote
Hello, can someone give me a little help...?
... Where is the ELAB fuse (electrical shut-off valve of the fuel injection pump) located on a 1994 A6 2.5 TDI (C4)? I can't find that blasted thing, and my repair manual doesn't have the wiring diagrams.
After not finding anything anywhere else, I suspect it might be located in the lower right corner of the passenger footwell, or am I wrong? What is the amperage rating of the fuse? Or does anyone happen to have a wiring diagram?
Thank you for the tips and greetings.
Burki.
Translated on 22-08-2026, 0:34.
bastion
Karma: +6 / -1   Thank you, like it!
Post20-10-2006, 8:04    Subject: A6 2.5 TDI: Fuse Location (C4) Quote
Is that located slightly below and to the side of the ESP (Electronic Stability Program) unit?
A4 Avant 08/01 AWX 05/08-
Translated on 22-08-2026, 0:35.
bastion
Post20-10-2006, 8:05    Subject: A6 2.5 TDI: Fuse Location (C4) Quote
There might still be a few safety devices hidden in the water tank according to the German Machinery Safety Act (Maschinenrichtlinie).
Burki
Post20-10-2006, 12:47    Subject: Best German Shepherd Breeders: Find Yours Now! Quote
Okay guys, the ELAB is located on top of the ESP unit, and I'm looking for the fuse that goes with it (not the ELAB itself). It's not listed in the fuse box inside the water tank, and my MStG (engine control module) is located under the rear seat, but there's no fuse there either...
Best regards, Burki.
Translated on 22-08-2026, 0:36.
Rudi
Post20-10-2006, 15:30    Subject: A6 2.5 TDI: Fuse Location (C4) Quote
According to my documentation, the N109 (Plus) is directly connected to pin 3 of the MSTG.
It obtains its mass from a mass connection located in the engine compartment wiring harness.
Rudi
Translated on 22-08-2026, 0:37.
klopfer
2007 Audi A4 Avant
Post20-10-2006, 18:25    Subject: A6 2.5 TDI: Fuse Location (C4) Quote
@Burki:
Is the MSG really located under the rear seat? In my opinion, the ABS is likely to be found there instead; the MSG is probably in the footwell on the passenger side.
Please correct me if I'm wrong...
Audi A4 Avant 2,0 l TDI (MKB = BRD) Baujahr 01/2007
christians
Post21-10-2006, 23:21    Subject: A6 2.5 TDI: Fuse Location (C4) Quote
In my case, it was located in the passenger footwell.
Gruß Christian
Translated on 22-08-2026, 0:38.
Burki
Post22-10-2006, 8:35    Subject: Possible Causes: Troubleshooting & Solutions Quote
Hi, it's possible that the MSTG (Multi-System Control Unit) is located in the passenger footwell, and that the ABS (Anti-lock Braking System) module is under the rear seat bench... but definitely not in the water container, as that only contains relays and fuses, and certainly not any for the ELAB (Electric Load Analysis Box).
If the ELAB is directly connected to the MSTG without any protection, I don't want to imagine what would happen if there was a short circuit. Or is that not critical? By the way, in my setup, it gets its ground connection through the fuel injection pump (where it's screwed in) and/or the engine block/body.
Translated on 22-08-2026, 0:39.
Rudi
Post22-10-2006, 9:54    Subject: Possible causes: Troubleshooting guide. Quote
...If the ELAB is directly connected to the MSTG without any protection, I don't want to imagine what would happen if there's a short circuit.
Either the semiconductor switch in the MSTG demonstrates its short-circuit withstand capability, or...
The friendly person makes a leisurely €1800 in sales ( icon_eek.gif ).
Rudi
Translated on 22-08-2026, 0:40.
No new posts Erwin - Looking for a repair manual for VAG vehicles Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Location of Comfort Control Unit, Passat 3BG Diesel Engine Technology
No new posts ELAB: Always Use a Pen? Diesel Engine Technology
No new posts EDC15: AEL/ACV/AJT Engine - ELAB Not Opening Diesel Engine Technology
No new posts Glow Plug Replacement Audi A6 C4 AEL Diesel Engine Technology
