AC Compressor Replacement: 96kW to 85kW (Sharan)
jaguar
Post10-12-2006, 15:55    Subject: AC Compressor Replacement: 96kW to 85kW (Sharan) Quote
"Due to a failure in the climate control module (STG) of an 85kW PD Sharan manufactured in 2001, a used part from a 96kW vehicle will be used. Do I need a special LOGIN code to reprogram the climate control module for the new engine, or can the coding be changed without one?"
Has anyone ever done this before, or is anyone familiar with it?
Thank you in advance.
Translated on 18-09-2026, 18:41.
No new posts PD Motor Workshop: 96kW, Servo Return Hose Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Oil proliferation in the ASZ. Incorporate PDEs and images Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Pan: Same for 85kW/96kW Engines? Diesel Engine Technology
No new posts Idling speed control 85kW PD /AJM Diesel Engine Technology
No new posts TDI 96kW: Top Speed 130 km/h Diesel Engine Technology
No new posts 96kW TDI ASZ Idle Vibration Issues Diesel Engine Technology
