Accessing Car ECUs: How-To Guide
edward
Post27-11-2006, 15:47    Subject: Accessing Car ECUs: How-To Guide Quote
Hello everyone,
Today I tried to access the control units (ECUs) in my Audi A6 Avant 2.5 TDI quattro, but unfortunately without success. I tried using several versions of VAGCom (208, 302), and I was only able to access the following ECUs: 01, 02, 03, 17, 25, and 33.
'These [devices/adapters] simply don't work for things like the interior lighting (which blinks when you try to activate it) or the navigation system ('Diag.' briefly appears on the RNS-D display)...'
Do I need a different diagnostic adapter, or do I need to change a setting in VAGCom?
Translated on 01-10-2026, 0:08.
Karma: +807 / -0   Thank you, like it!
Post27-11-2006, 16:44    Subject: Accessing Car ECUs: How-To Guide Quote
Just use a decent diagnostic system and avoid outdated, pirated software. Then it will work.
http://shop.dieselschrauber.de/product_info.php/products_id/45 or
http://shop.dieselschrauber.de/product_info.php/products_id/46
Translated on 01-10-2026, 0:09.
edward
Post27-11-2006, 17:47    Subject: Accessing Car ECUs: How-To Guide Quote
Hello Rainer,
Thank you for your reply. That sounds quite good in principle, but is the problem due to the adapter or the software? It's not entirely clear from your post, as the links offer both the software and the corresponding hardware. And that's exactly what my question was about: whether I can continue to use my existing hardware.
Translated on 01-10-2026, 0:10.
bastion
Karma: +6 / -1   Thank you, like it!
Post28-11-2006, 7:30    Subject: Accessing Car ECUs: How-To Guide Quote
You can continue to use your old hardware, but it will only function as shareware. This is because the software's registration code is stored in the new adapter.
And it's your software's fault. It's poorly copied and simply outdated.
A4 Avant 08/01 AWX 05/08-
Translated on 01-10-2026, 0:11.
No new posts EDC15: Updateable Engine Control Unit Software Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ECU Data: Access Issues & Troubleshooting On-Board Diagnostics (OBD)
No new posts I can't access the service mode of the Climatronic! Transmission, Chassis, Body & Interior
No new posts G3 AFN Power Loss: Troubleshooting Guide Diesel Engine Technology
No new posts Gear Shift Problem: 5th Gear Not Engaging Transmission, Chassis, Body & Interior
