05-12-2002, 17:32 Subject: VAGCOM label files? |
Hello everyone.
The label file I downloaded from Auto-Intern did not include all the measurement groups for my AFN engine control unit, and it was only partially useful for "labeling" the data windows. Therefore, I modified it to suit my needs.
How are VAGCOM users doing with other engines? Have you/did you experience similar problems, or do you know of a source for (German!) labels that properly explain all the measurement groups and whose text fits perfectly into the VAGCOM screens?
Would you consider a collection of "optimized" label files to be useful, which ideally would offer the right settings for every TDI – if Rainer could create such a thing and was willing to do so?
The collection would naturally need to be populated by VAGCOM users of the forum, as a single person typically wouldn't have access to all engine versions needed to test the labels. Gruß Ulf
Translated on 18-07-2026, 19:36.
Profile PM Garage |
Maik Guest
06-12-2002, 8:54 Subject: VAGCOM label files? |
I would also be very interested in having correct label files for a 1Z.
I would also be happy to help with testing.
Maik.
Translated on 18-07-2026, 19:38.
Arne Guest
06-12-2002, 10:29 Subject: VAGCOM label files? |
'@ulf - 'You have mail.'
arne
06-12-2002, 16:46 Subject: VAGCOM label files? |
Maik wrote: | Hi,
I would also be happy to help with testing. |
Hi Maik,
I'm sending you my number from the AFN. Since our service numbers are likely the same except for the last few digits, it might work for you too.
If necessary, open (Wordpad or a similar program) and rewrite the text. Gruß Ulf
Translated on 18-07-2026, 19:39.
Profile PM Garage |
olbetec Schrauber
Joined: 08/14/2002 Posts: 76 Karma: +4 / -0 Location: Garbsen bei Hannover
06-12-2002, 17:35 Subject: ATD label files |
Okay, I'll do it right away and modify my file to include the target values (idle and WOT at 3000 RPM).
"Only my target values are from a 1.4L TDI engine, as the ECU is very similar. Therefore, they are quite basic values for a 1.9L 74kW ATD..."
If anyone has access to the target values of an ATD, I can make that available for the turbodiesel community...
Checked thoroughly.
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Fabia I TDI, EZ06/01 (1,9/74kW, ATD)
Octavia II TDI DSG EZ11/06 (2,0/103kW, BMM)
Translated on 18-07-2026, 19:41.
07-12-2002, 13:37 Subject: Explanation |
Hello again.
Given the relatively limited response so far, I wonder if the function of label files is generally well-known among VAGCOM users.
Therefore, here are a few "just in case" tips.
The car provides only "raw" values in the measurement data blocks, which are not automatically self-explanatory.
Example Group 7 of the AFN:
Here, three temperature values from the sensors for fuel, coolant, and intake manifold are displayed. This allows you to quickly check if all three sensors are working correctly when the engine is cool.
If the three data fields display values such as 10.8°C, 30.4°C, and 10.4°C, it becomes clear that the "average" sensor is not functioning correctly.
But which of the three donors is it?
VAGCOM (as far as I know, from version 81 onwards) can access a corresponding label file during the diagnostic process, which allows the measurement groups and data windows to be "labeled".
In the example mentioned, a heading like "Temperature Sensor Comparison" could be displayed above four data windows labeled as follows: "Fuel - empty - Intake manifold - Water." This would immediately indicate that there is an issue with the intake manifold sensor.
For example, when logging boost pressure data using Group 11, it would immediately be clear which of the two pressure values represents the target value and which represents the actual value, without having to sift through huge lists to understand the meaning of the measured values.
The label files are stored in a folder named "Labels" within the VAGCOM directory and are sometimes included during download, depending on the source. However, they are often incomplete, or the file for your specific engine is completely missing, or it is only written in English...
When using the dialog function, VAGCOM accesses the file whose name matches the first 9 digits of the VAG part number, which is displayed in green when the connection is established. This applies not only to the engine but to all control units that support measurement blocks, such as ABS, etc.
If a file with the appropriate name is missing, VAGCOM may display guesses about the meaning of the data in the data windows – which can be unreliable and misleading.
The label files can be edited in plain text using programs like Wordpad; you can correct, add to, or rewrite them (e.g., from English to German), etc. The folder is not protected, meaning that missing or better files can be imported, and unnecessary files can be deleted, etc. Gruß Ulf
Translated on 18-07-2026, 19:44.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
07-12-2002, 23:41 Subject: VAGCOM label files? |
Hello Ulf,
Quote: | | Given the relatively low response so far, I wonder if the function of label files is generally well-known among VAGCOM users. |
Sure, but everything looks great on my OBD scanner... I rarely use it on other cars.
Translated on 18-07-2026, 19:48.
Profile PM WWW Garage |
08-12-2002, 0:19 Subject: VAGCOM label files? |
Rainer K. wrote: |
That's true, but on my AHF, everything looks great... |
Hi Rainer,
Then you probably had more luck with your labels than I did (see my initial post), if you didn't have to rewrite or supplement them.
Perhaps poorly designed files available for download (like mine) are truly the exception... Gruß Ulf
Translated on 18-07-2026, 19:49.
Profile PM Garage |
Gremlin Guest
08-12-2002, 3:03 Subject: VAGCOM label files? |
My ALH is also showing everything perfectly.
'But I wanted to write something about the comfort steering system and the ABS.'
When it gets warmer again and the days get longer...
CU Gremlin.
Translated on 18-07-2026, 19:50.
Varianti Guest
11-12-2002, 22:09 Subject: VAGCOM label files? |
I also think it would be useful to have a download area for the corresponding, verified label files. This way, users could enhance their own VAG-Com devices for other types of vehicles as well.
Thank you, Ulf, for your label file.
Translated on 18-07-2026, 19:51.
Eugli Guest
16-12-2002, 21:00 Subject: VAGCOM label files? |
I'm searching in my version but can't find the place where I can view the labels.
(Do I need to be docked?)
16-12-2002, 21:06 Subject: VAGCOM label files? |
Eugli wrote: | | I've searched in my version but can't find the place where I can view the labels. (Do I need to be docked?) |
Hi.
If you mean "dialog operation" in the context of being docked.
"Labels" are only used in the dialogue, yes.
You can read and edit them in the "Labels" folder within the VAGCOM directory.
More details can be found in this thread above, under "Explanations." Gruß Ulf
Translated on 18-07-2026, 19:52.
Profile PM Garage |
