"For caravan owners or small freight carriers, the tendency to sink into the ground when loaded is a recurring problem. This is especially unpleasant when towing a caravan, as the support wheel can quickly bottom out and hit the road. Besides the risk of damaging or losing the support wheel, this situation can also be dangerous. Those who have a leveling system installed in their vehicle are in a better position. Unfortunately, retrofitting such a system is often not possible or is very complex. In principle, there are several options:"
- Installation of standard parts (if available and possible retroactively --- very expensive).
- Installation of shock absorbers that automatically adjust the vehicle's ride height (affordable, available for a limited number of vehicles; options include Monroe Level Light + Sachs Niveaumat).
- Installation of an air suspension system with automatic leveling (very expensive... but the "luxury version").
- Installation of additional air bladders to support the main spring.
The latter alternative is not necessarily cheap either, as some providers offer automatic leveling via regulated air pressure.
A simple solution is offered by the company
MAD. They have a simple system for many vehicles that is inserted into the existing suspension and then inflated with air pressure at the gas station. This prevents the rear of the vehicle from sinking as much when loaded.
http://www.mad-vertrieb.de/luftfedern_frames.htm
The entire system for my Golf cost 268 euros and was completely installed in under two hours.
For the Golf 4, you need to lift the entire car and detach the shock absorbers from underneath. The springs will then almost fall out of their housings on their own. The rubber bellows are depressurized and sealed. Then, they are inserted into the coils of the springs.
Alles weider zusammen bauen. Ready.
The remaining assembly time is used for installing the air hoses and the electrical components (vacuum warning system).
The system should be operated with a minimum pressure of 0.5 bar and a maximum pressure of 2.5 bar. To prevent overpressure in the system, a valve is installed that automatically releases the pressure at 3.5 bar. The low-pressure warning activates at a minimum pressure of 0.2 bar, at which point a buzzing sound will be heard. It's then time to visit the next gas station to "refill" the air.
Those who desire more comfort can install a small air compressor (around ~15 euros) in their car, which can be used to generate the necessary pressure.
Opel offered a similar system in various station wagon models years ago (e.g., the Astra F). I thought this simple version of a leveling system was brilliant.
Here's how it looks when it's installed:
