Adjusting Tiptronic shift points?
edward
Post08-12-2006, 9:55    Subject: Adjusting Tiptronic shift points? Quote
Hello everyone,
Can the shift points of a Tiptronic transmission be reprogrammed? For example, that the gear shift now occurs at a lower engine speed than before?
x world one
Post10-12-2006, 22:06    Subject: Adjusting Tiptronic shift points? Quote
Your A6 should have the ZF transmission. You can switch it to sport mode, for example. On your Audi, this should be possible via a button on the gear lever. On my Passat, it can only be done by reprogramming the control unit. Then the TT will shift up more quickly, or it won't stay in the same gear for as long when you're coasting after accelerating.
However, this makes driving significantly less harmonious, and often the faster upshifting is problematic because, especially in stop-and-go traffic, the transmission constantly shifts back and forth. If you want precise shift points tailored to your preferences, you need to use a switch or drive in "tip" mode.
Spritmonitor
edward
Post10-12-2006, 22:13    Subject: Adjusting Tiptronic shift points? Quote
Sure, I have the S-mode enabled on the Tiptronic. I just assumed that it would shift at a higher RPM (sportier driving = higher RPMs = later shifting). What I meant was the opposite of that icon_wink.gif.
x world one
Post11-12-2006, 14:10    Subject: Adjusting Tiptronic shift points? Quote
Well, you're right about that. The Tiptronic transmission only shifts up to a higher gear after a certain RPM range. Let's say, above 2000 RPM. The thing is, the Tiptronic will initially maintain that reached 2000 RPM when driving at a constant speed. So, in third gear at 50 km/h, the engine will be running at 2000 RPM. Then the Tiptronic only shifts up after a few seconds, or after a noticeable delay.
With the sport mode, it's now possible to achieve near-instant upshifts with the Tiptronic transmission; it doesn't wait as long to shift up when driving at a constant speed.
It's not possible to change the shift points of the Tiptronic, for example, to have it shift at 1500 rpm instead of 2000 rpm, at least not using standard onboard settings. In the US, there are apparently specialists who can reprogram the control unit. However, I don't know if it's worth it, or how compatible it is with the transmission's durability. The thing is, a certain amount of torque needs to be present for the TT to be able to shift gears at all.
Spritmonitor
Ross-Tech-Support
Post11-12-2006, 15:36    Subject: Adjusting Tiptronic shift points? Quote
Please provide us with a diagnostic report.
x world one
Post12-12-2006, 13:56    Subject: Adjusting Tiptronic shift points? Quote
Does your question imply that the adjustment of the switching points might be possible through adaptation?
Spritmonitor
Ross-Tech-Support
Post12-12-2006, 13:59    Subject: Adjusting Tiptronic shift points? Quote
From my question, you can tell that I would like to review a diagnostic report before I make any specific comments.
x world one
Post13-12-2006, 9:49    Subject: Adjusting Tiptronic shift points? Quote
Okay, I can post something about my Tiptronic because I'm really interested in it. I am always interested in learning new things about the TT.
I have a full version of VAGCOM with a HEX-USB interface.
What exactly should I log or check in the transmission control unit (TCU) for that?
I would then post a log.
Spritmonitor
Ross-Tech-Support
Post13-12-2006, 11:49    Subject: Adjusting Tiptronic shift points? Quote
Diagnosis report/automatic scan is sufficient.
x world one
Post22-12-2006, 9:30    Subject: Adjusting Tiptronic shift points? Quote
Okay, here's the excerpt from the Autoscan.
I only picked up the car from the workshop the day before yesterday, and I immediately took the opportunity to clear all the error codes. I also posted about the MSTG (presumably a specific topic or law) in case it might still be of interest.
[code]
Address 01: Engine
Part No: 8D0 907 558 E
Component: 1.8L R4/5VT MOTR AT D02
Coding: 04051
Shop #: WSC 05314
Address 02: Automatic Transmission.
Part No: 8D0 927 156 BK
Component: AG5 01V 1.8l 5VT RdW D70
Coding: 00000
Shop #: WSC 00000
Unfortunately, it seems that the mileage cannot be determined from the control unit icon_sad.gif of my car.
Spritmonitor
Rainerfrank
Post22-12-2006, 10:06    Subject: Adjusting Tiptronic? Quote
Hello everyone,
"I'm also very interested in that. I have an older ZF automatic transmission, model AG5 01V RDW 9419 (from a 1999 A6 with the AFB engine). In "D" mode, the automatic transmission shifts up in the lower gears much too late (it roars like a lion, hence the "tractor" sound), around 2500 RPM, when an earlier upshift would be possible. However, if I switch to Tiptronic mode, I can select the next gear as low as 1600 RPM." Supposedly, the TT software is supposed to be able to learn, but I haven't noticed much of that myself.
When I compare the A6 to our A3 2.0 TDI with DSG, the A6 shifts gears much earlier (at 1400 RPM).
as is typical for a diesel engine with high torque.
What's also annoying is the shifting between gears, specifically between second and third.
"The TT is enabled, but it's not displaying."
Is there perhaps an update from Audi or ZF? How can I find out?
Best regards, Rainerfrank.
Ross-Tech-Support
Post22-12-2006, 11:35    Subject: Adjusting Tiptronic shift points? Quote
There are no updates available for the older 01V models, and there won't be any in the future. Regarding encoding, you should take a look at this: [link/reference].
text
http://wiki.ross-tech.com/index.php/5-Speed_Automatic_Transmission_%2801V%29
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tiptronic Shift Points / VTG Vacuum Pump Diesel Engine Technology
No new posts Tiptronic On-Board Diagnostics (OBD)
No new posts Tiptronic: 4-Cylinder Engine Performance Diesel Engine Technology
No new posts Tiptronic 01V: Replacement Parts & Number Transmission, Chassis, Body & Interior
