Intermittent Fuel Vent Issues: Troubleshooting Guide
fred999
Post26-06-2005, 20:19    Subject: Intermittent Fuel Vent Issues: Troubleshooting Guide Quote
I have a Golf 4 (model year 2003) – the warranty just expired. For a few weeks now, the display has been showing "Exhaust - Workshop." A diagnostic scan of the engine control unit shows an intermittent fault code related to the fuel tank ventilation system.
After the error is reset, there is usually a period of 3-4 weeks of stability, after which the error reappears.
The workshop keeps resetting the error.
Does anyone have any ideas?
fred
Translated on 09-09-2026, 13:25.
fred999
Post27-06-2005, 18:53    Subject: Intermittent Fuel Vent Issues: Troubleshooting Guide Quote
Okay, I've just read the error codes.
VAG-COM Version: DRV 311.3-S
Control unit part number: 036 906 034 DR.
Component or version: MARELLI 4MV 4464
Software Coding: 0000031
Workshop Code: WSC 01391
"1 error found:"
16825 - Tank ventilation system: Flow rate error.
P0441 - 000 - -
After resetting the error, the warning light is off, and the display shows "Exhaust - Workshop".
"It's also gone. However, if I drive a few kilometers, the same error code reappears in the error memory, but the warning light and the display indicator remain off?"
The error is only stored in the error memory.
fred999
Translated on 09-09-2026, 13:27.
vagtuning
Post10-07-2005, 10:20    Subject: Intermittent Fuel Vent Issues: Troubleshooting Guide Quote
Well, in that case, I would also assume there's an error that exists.
Okay, here's a random guess, but it's a fairly common issue: The AKF valve is stuck/broken.
The error memory entry is set when the error occurs for the first time. If the error does not reappear, it is set sporadically. If the error is detected again during subsequent tests, and the entry is already in the memory, a counter is incremented. Depending on the design, the control system may also trigger an alert after the 3rd or 5th occurrence of the same error within a specific test period.
Furthermore, it could be a software error within the control unit.
Please take your car to the dealer and have them use the latest flash CD to check if there's a new software version available for the car. There definitely is a newer version, but I'm not sure if it's the one you already have installed.
For your information, this is a BCB engine (1.6L 16V).
Translated on 09-09-2026, 13:29.
fred999
Post26-12-2006, 11:39    Subject: Intermittent Fuel Vent Issues: Troubleshooting Guide Quote
You're welcome, vagtuning.
I replaced the AKF valve, and the error is gone.
Thank you again for the helpful and informative response.
Fred999
Translated on 09-09-2026, 13:31.
vagtuning
Post26-12-2006, 13:29    Subject: Intermittent Fuel Vent Issues: Troubleshooting Guide Quote
Glad it helped!
Ross-Tech-Support
Post26-12-2006, 16:48    Subject: Intermittent Fuel Vent Issues: Troubleshooting Guide Quote
http://wiki.ross-tech.com/index.php/16825/P0441/001089
No new posts ABS Light On: VW Transporter T4 Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L, Golf 4 etc. - Turn signal relay is malfunctio... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 8E2 Wiper Problems: Fix Sticking Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB, Nadelhubgeber, sporadisch auftretender Fehler Diesel Engine Technology
No new posts P2002 Error: A4 B8 2.0 TDI CNHA - Troubleshooting Diesel Engine Technology
No new posts Load pressure regulation difference, intermittent?? Diesel Engine Technology
No new posts ESP Warning Light: Causes and Solutions On-Board Diagnostics (OBD)
