Differences in MSG for Audi 2.5 TDI AAT engines
Hazie
Post09-02-2007, 13:15    Subject: Differences in MSG for Audi 2.5 TDI AAT engines Quote
Hopefully, someone can help me.
I have an Audi 100 2.5 TDI with engine code AAT and manufactured in 1993.
This one has a message with the label:
Bosch.
0 265 100 056
Probably the serial number is located in the white box.
366 11924
VW/Audi Part No. 4A0 907 379A
"From my accident car with the same engine code (MKB) but manufactured in 1991, I have an ECU (engine control unit) with the following label:"
Bosch.
0 265 100 037
262 03865
VW/Audi Part Number: 443 907 379 C
I want to have the MSG (engine control unit) from a 1991 Audi chipped and then install it in my current car.
The question is whether the control units are the same and if everything will work icon_question.gif.
According to the default data table in the FAQ, both control units are version 1.
The 1991 Audi didn't have an airbag, unlike my current car.
Could it be that in older control units, the airbag control unit is integrated into the main system module (MSG)?
It would be really helpful if someone could assist me or take a look at this.
Markus.
Audi 100 Avant 2.5TDI
BJ.93 / AAT mit 315TKm
6,8l/ 100km
mit Austauschmotor
Translated on 17-07-2026, 14:50.
Rudi
Post09-02-2007, 17:09    Subject: Differences in MSG for Audi 2.5 TDI AAT engines Quote
Um... what you found there isn't the engine control unit, but it's...
from the ABS.
A friend has some AAT MSTGs available. If you are interested, please send me a private message icon_arrow.gif.
Rudi
Translated on 17-07-2026, 14:53.
Karma: +808 / -0   Thank you, like it!
Post09-02-2007, 17:13    Subject: Differences in MSG for Audi 2.5 TDI AAT engines Quote
If I remember correctly, the engine control unit (ECU) in an Audi 100 is not located in the engine compartment. You'll need a carpet knife.
Translated on 17-07-2026, 14:54.
Rudi
Post09-02-2007, 17:18    Subject: Differences in MSG for Audi 2.5 TDI AAT engines Quote
Yep.
The MSTG is located on the passenger side (footwell) behind the carpet.
Number: 4A0 907 401
Hazie
Post09-02-2007, 22:06    Subject: Differences in MSG for Audi 2.5 TDI AAT engines Quote
Awkwardly awkward...
The amazing thing was under the back seat.
Let's look at them one by one.
Thank you for the very helpful and quick tips icon_exclaim.gif.
But why are the ABS control units different from each other?
Has anything significant happened recently?
If someone is interested, they can purchase the item.
Markus.
6,8l/ 100km
mit Austauschmotor
Translated on 17-07-2026, 14:55.
bastion
Karma: +6 / -1   Thank you, like it!
Post10-02-2007, 0:10    Subject: Differences in MSG for Audi 2.5 TDI AAT engines Quote
It likely uses more advanced and integrated technology, which saves the manufacturer money and storage space.
A4 Avant 08/01 AWX 05/08-
Translated on 17-07-2026, 14:56.
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Timing Belt Audi AAT: Old vs. New Differences Diesel Engine Technology
No new posts Differences Audi 2.5 V6 TDI Engines Diesel Engine Technology
No new posts Audi 80 Cabriolet 1Z to AFN: Differences in Engine Contro... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi B4 Steering Rack: Differences & Replacement Transmission, Chassis, Body & Interior
