Audi A6 C4 Door Handle Repair: Fix Broken Handle
dakoal
Post27-01-2007, 11:11    Subject: Audi A6 C4 Door Handle Repair: Fix Broken Handle Quote
Since it has gotten a bit colder here recently, the driver's door and the passenger door can only be opened from the outside.
This morning, I completely disassembled the driver's side door.
(You need to disconnect/remove things like the trim, window mechanisms, and cables.)
After that, I finally arrived at the castle.
It was quickly investigated, and the culprit was found.
The lever to which the cable for operating the lock was attached was completely rusted and lubricated with a grease that was not cold-resistant. This grease crumbled into small pieces when I moved the lever slightly. After lubricating everything with VW grease (which also goes into the door hinges) and moving the lever back and forth 50 times with pliers, I thought everything was fine.
Reinstalled, the door was opened from the inside once, then it came off its hinges because the lever remained in its position, but the cable retracted again ---AAARRRGGHHHH---.
So, I removed the lock again and secured the latch with a piece of copper wire.
Now it's stopped.
http://members.aon.at/struber/images/Audi-Schloss.jpg
Sure, here's the translation:
"Best regards," or "Sincerely,".
writing with frozen fingers.
dakoal
____________________________________
Audi A6 Avant (C4) 2,5TDIi MKB:AEL, BJ 1995 @ 220tkm //www.spritmonitor.de/image_116461_1.png
VW Golf III 1,9D MKB:1Y, BJ 1995 @ 182tkm R.I.P. (Rest in Poland)
Translated on 18-10-2026, 8:33.
Back to top Profile PM Email
No new posts Steering play VW T5/T6 (solution) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The solution to the puzzle!!! 1Z power loss Diesel Engine Technology
No new posts Clutch Problems AVF: Find a Permanent Solution Diesel Engine Technology
No new posts New solution for unstable idle AXR Diesel Engine Technology
No new posts Golf 5+ Central Locking Problem & Fix! On-Board Diagnostics (OBD)
