The problem is as follows:
When the accelerator is fully pressed, the actual injection start timing drops dramatically to 0 around 3500 RPM.
At 4000 RPM, the actual value is approximately 4-6° VOT (target is 15.4° VOT). The engine is misfiring and producing extreme smoke!
That is understandable
When driven with a moderate load, everything works fine!
The car is not chipped. The pump settings are correct (timing is in order).
'Errors related to the injection molding process, outside of the normal tolerance range, are naturally stored in the memory.'
I will next remove the valve for the fuel injector and check the small filter to see if it is clogged. (The valve seems to be electrically okay so far.)
Unfortunately, the pump has to be completely removed for this job.
You can't get it out when it's installed.
I don't have any other ideas at the moment.
What do you think about this problem?
Sure, here's the translation:
'Best regards,' or 'Sincerely,'.
Kim R.
