Golf 3: Wiring Harness for Car Radio Installation
FaBu
Karma: +3 / -1   Thank you, like it!
Post27-01-2007, 20:26    Subject: Golf 3: Wiring Harness for Car Radio Installation Quote
Hello, I'm having a small problem with the switched + for the radio. I connected the lighting (LDA) to the radio. Now the lamp is broken, and after replacing it, nothing works anymore. There's a constant + and a - connection, but the switched + through the ignition is no longer working. Why? Fuse 22 is okay, and everything else is working. Where else can I look, or which cable can I tap into to power the radio?
Fabian
Bj.97 Golf Vari. AHU/CTN def.AGR;-)
100km/5L
0,216 Düsen, Kaufmann Chip,VR6 LuFiKa
Translated on 11-10-2026, 15:10.
D. Kurz
Post28-01-2007, 19:51    Subject: Golf 3: Wiring Harness for Car Radio Installation Quote
Hello!
It's possible that the radio connection in your ignition switch is faulty. You can check this by seeing if a warning buzzer works. Turn on the engine, turn on the lights, and open the doors – if the buzzer sounds, that's a good indication. Replacing the ignition switch contact isn't very expensive if that's the problem.
Dominique.
Translated on 11-10-2026, 15:11.
BM
Avatar-BM
Post28-01-2007, 21:55    Subject: Golf 3: Wiring Harness for Car Radio Installation Quote
It's possible that the radio connection is faulty in your ignition switch.
Yeah, and the contact is only designed to switch a relay.
3B5 AJM
Translated on 11-10-2026, 15:12.
Post28-01-2007, 23:32    Subject: Golf 3: Wiring Harness for Car Radio Installation Quote
BM wrote:
Sure, and the contact is designed, at best, to activate a relay.
But only with a varistor and a maximum operating current of 250mA.
The S-contact is designed for a maximum of 500mA. This contact in the ignition switch often burns out if "high power" devices are connected carelessly. There are some radios that are particularly prone to this issue.
Translated on 11-10-2026, 15:13.
FaBu
Post29-01-2007, 13:47    Subject: Golf 3: Wiring Harness for Car Radio Installation Quote
Thank you for the answers; I will now get started and see what can be done. I will report back! icon_biggrin.gif
But first, I need to pass this cold on, it's so incredibly annoying... icon_sad.gif
Fabian
100km/5L
Translated on 11-10-2026, 15:14.
FaBu
Post03-02-2007, 20:12    Subject: Golf 3: Wiring Harness for Car Radio Installation Quote
Can I also switch the radio using a different 15-gauge wire? I don't want to have to constantly replace the ignition switch at the VW dealership. Which wire would be suitable?
Fabian
100km/5L
No new posts Golf 5 Radio Volume Problem - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Radio: Won't Turn On After Parking? (8Z0) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Radio Coding: How-To Guide Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf V/Touran: Radio Unlock/Deactivate Electrical Systems, Vehicle Electronics, Multimedia
No new posts Skoda Radio Symphony in Golf 3 Electrical Systems, Vehicle Electronics, Multimedia
No new posts VW Radio Connector: Golf 2000s Wiring Diagram Diesel Engine Technology
