Boro wrote: |
Actions, Relay 109 replaced
Powerbox removed and pump connector treated with contact spray
Diesel additive/cleaner added to fuel
I'll probably have to tackle cleaning the bulk separator myself, or does anyone have any other suggestions for now? |
Yes: thoroughly clean the pump connectors with brake cleaner and then protect them from corrosion with acid-free oil.
Reason: Many contact sprays are aggressive. While they do remove corrosion, they quickly form new corrosion through their residues -> the metal "becomes addicted", and you have to reapply them every few weeks until the connectors eventually break down.
