Immobilizer Adjustment: Engine Control Unit Settings
GoraDriver
Post19-02-2007, 11:50    Subject: Immobilizer Adjustment: Engine Control Unit Settings Quote
Hello, I have a question.
Is it possible to adjust the immobilizer settings in the engine control unit using VCDS (VagCom) so that you can continue to use the old keys and the old instrument cluster after an engine swap, along with the new engine control unit?
I would be grateful for every answer...
Translated on 20-08-2026, 23:06.
Post19-02-2007, 12:01    Subject: Immobilizer Adjustment: Engine Control Unit Settings Quote
A Volkswagen Golf 1 does not have an immobilizer!
You must accept exactly these complete and correct answers if you don't tell us which tractor we are talking about icon_wink.gif.
Greetings.
Translated on 20-08-2026, 23:07.
GoraDriver
Post19-02-2007, 12:08    Subject: Immobilizer Adjustment: Engine Control Unit Settings Quote
Okay... I'm really sorry about this.
Okay, so I have an AJM engine and I want to install an ARL engine.
And that's why my question is: since the engine control unit needs to be replaced, I was wondering if I can adjust the immobilizer built into the new ECU myself using VAGCOM, so that the car will still start after the conversion.
Translated on 20-08-2026, 23:08.
Ross-Tech-Support
Post19-02-2007, 19:05    Subject: Immobilizer Adjustment: Engine Control Unit Settings Quote
What are the production/model years of the AJM and the ARL?
Please be more specific (e.g., with the production/model years), and then we can actually help – so far, you're just getting in your own way... icon_wink.gif
Translated on 20-08-2026, 23:09.
GoraDriver
Post20-02-2007, 0:51    Subject: Immobilizer Adjustment: Engine Control Unit Settings Quote
Sorry again...
Okay, so my AJM engine is from a car manufactured in 1999, and the ARL engine that I'm going to install is from a car manufactured in 2000.
It seems to be more complicated than I thought.
Ross-Tech-Support
Post20-02-2007, 0:56    Subject: Immobilizer Adjustment: Engine Control Unit Settings Quote
Since the production year and model year don't always align, a vehicle produced in 1999 could very well be a 2000 model year, while a vehicle produced in 2000 could be a 2001 model year. Therefore, it would be helpful to be more specific. While both are definitely WFS-2 compliant, the question is whether the wiring is compatible (specifically regarding CAN).
Translated on 20-08-2026, 23:10.
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Help, I can't adjust my immobilizer On-Board Diagnostics (OBD)
No new posts Adjusting the engine control unit (ECU) for a VW Sharan. On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Adjust the engine control unit (ECU) for Audi A3/8P On-Board Diagnostics (OBD)
No new posts Wegefahrsperre, Kombiinstrument, Motorsteuergerät anpass... Diesel Engine Technology
