The counter nut on the VTG rod won't tighten
wuze60
Post14-11-2002, 21:40    Subject: The counter nut on the VTG rod won't tighten Quote
Hello everyone!
I'm having the following problem: I can't seem to get the lock nut on the VTG linkage off. Is it extremely difficult to loosen from the factory, or am I just having bad luck? icon_cry.gif
Are there any tips or tricks for how to easily open a stuck jar?
I don't want to damage the icon_rolleyes.gif rod or the nut .
Post14-11-2002, 22:03    Subject: The counter nut on the VTG rod won't tighten Quote
If you force the nut open, you can easily bend the rod. Therefore, you need to hold it in place with pliers or something similar.
If a standard adjustable wrench is overtightened (which hasn't happened to me so far), there are open-end wrenches available.
wuze60
Post14-11-2002, 23:34    Subject: Adjustable wrench Quote
Greetings, Rainer
Thank you, Rainer.
So far, I've just been taking things cautiously.
I'll try holding it in place with pliers and then see if I can loosen it with a wrench.
I just wasn't sure if the thread locker, the adhesive, could be removed.
Sure, here's the translation:
'MFG' is an abbreviation for 'Mit freundlichen Grüßen,' which translates to 'Sincerely' or 'Best regards' in English.
zzzZZ
Post15-11-2002, 8:52    Subject: The counter nut on the VTG rod won't tighten Quote
My mother's belly hasn't moved even a millimeter, and now I can't even feel her anymore. I was even thinking about heating it up to see if I could somehow loosen the adhesive. However, I don't dare to do that while it's installed.
René K.
wuze60
Post15-11-2002, 19:02    Subject: My mother wasn't that strict, actually Quote
Hey everyone!
The mother wasn't actually that heavy.
I was just afraid of damaging something, but with a short, firm pull, it came open immediately.
Thanks again for your replies.
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts The pre-heating lamp is not turning off. Motor does not s... Diesel Engine Technology
No new posts VTG-Gestänge einstellen Diesel Engine Technology
