AFN Cylinder Head Differences
Peter vdl
Post07-01-2007, 19:29    Subject: AFN Cylinder Head Differences Quote
Hi everyone,
My AFN needs a new cylinder head after the crankshaft bolt broke. Now, there are "up to engine number" and "from engine number" options. Does anyone know the difference(s)? I've been trying to figure out that one has 7mm valve stems and the other has 8mm. Could that be it? If so, which one is which? Are there any other differences?
Smoky greetings.
Peter.
Translated on 09-09-2026, 10:32.
Boro
Post09-01-2007, 14:22    Subject: AFN Cylinder Head Differences Quote
Okay, I only know of the AFN part number 028 103 373 N, which should have 8mm valve shafts. What other part numbers do you have available?
Translated on 09-09-2026, 10:33.
Peter vdl
Post04-03-2007, 16:32    Subject: AFN Cylinder Head Differences Quote
Then I'll have to figure out what's going on myself. Here are a few differences:
According to a certain uncle, the first 1Z and AFN cylinder heads were manufactured with 8mm valve stems. From AFN 002 001 onwards, different valve springs were used. In the Golf, 7mm valve stems were already used, while in the Sharan, 8mm valve stems were used. From AFN 430 892 onwards, both cars used 7mm valve stems and the new springs. You can obtain both types of heads: 028 103 265 EX for the complete head with 8mm valves, and 028 103 265 NX for the same part with 7mm valve stems. There is a warning on the head marked "EX" indicating that it may also have 7mm valves installed. I believe that after the old stock is sold, AuWeh will only offer heads with 7mm valve stems.
Smoky greetings.
Peter.
Translated on 09-09-2026, 10:36.
No new posts Document A6 4B, Fuel Leak at Cylinder Head Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Severe oil leak at the cylinder head, AJM engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts differences in the 1Z Diesel Engine Technology
No new posts Cable differences Transmission, Chassis, Body & Interior
No new posts SDI vs. TDI Fuel Injector Pump: Differences Diesel Engine Technology
No new posts ECU Names: Differences and Explanations On-Board Diagnostics (OBD)
