V6 TDI: Differences between engine codes AFB and AKN
mfdk
Post14-11-2002, 18:55    Subject: V6 TDI: Differences between engine codes AFB and AKN Quote
Since I now own a Passat with the V6 AKN engine, I'm interested in knowing what the differences are compared to the AFB engine.
Thank you in advance.
mfdk
Translated on 16-07-2026, 7:41.
godot
Post16-11-2002, 21:29    Subject: V6 TDI: Differences between engine codes AFB and AKN Quote
The number of pump plungers in the radial piston distributor injection pump has been increased by one. This increases the maximum injection pressure. In addition, it features six-hole instead of five-hole injectors and an improved crankcase ventilation system.
At least the first two measures likely serve to comply with the EU III emission standard.
Christian.
Translated on 16-07-2026, 7:42.
mfdk
Post17-11-2002, 15:38    Subject: V6 TDI: Differences between engine codes AFB and AKN Quote
Hello!
I am pleased that there is someone in this very competent and interesting forum who knew the answer to my question and made a contribution.
Thank you very much.
mfdk
Translated on 16-07-2026, 7:43.
No new posts Volkswagen Golf 1.9 TDI 74 - 77 kW Diesel Engine Technology
No new posts ALH vs. AFN Engine: Differences and Specs Diesel Engine Technology
No new posts Difference 1Z to ALH Diesel Engine Technology
No new posts 2.0 TDI CR: 143 PS vs. 120 PS - Comparison Diesel Engine Technology
