Radio AURA: Connector Pinout Information
Jochen_145
Post27-02-2007, 12:28    Subject: Radio AURA: Connector Pinout Information Quote
Hello everyone,
I am looking for the pinout diagram of the Seat 'AURA' radio.
Part number: 1M0 035 186 D
The goal of this search is to identify the speed signal that enables volume adjustment while driving.
I need this signal for measuring vehicle speed.
Is this signal located on the comfort control unit?
Part number: 1c0 959 799 E
If so, which pin?
Thank you for all the helpful information.
Best regards, Jochen.
Translated on 02-10-2026, 14:53.
mahk
Avatar-mahk
Post27-02-2007, 14:30    Subject: Radio AURA: Connector Pinout Information Quote
Look over there: http://www.selfmadehifi.de/kfz-iso.htm.
While SEAT isn't directly involved, several other OEM suppliers within the Volkswagen Group are.
Typ89 SB: 05/2000 120.000km - 01/2005 295.000km (unfall)
B5 Avant AEB 07/2005 166.000km ([email protected]) - 07/2007 195.000km (verkauft)
1K BMM: 03/2011 120.000 km - aktuell
Translated on 02-10-2026, 14:54.
Jochen_145
Post16-03-2007, 18:04    Subject: Radio AURA: Connector Pinout Information Quote
I've found something now.
To help others with their search, I'm posting the occupancy schedule:
Car radio:
Connector pinout - ISO standard (chamber C).
1 = Rear left line-out.
2 = Line-out, rear right.
3 = NF mass.
4 = Front left line-out.
5 = Line-out, front right.
6 = Switching voltage (remote).
7 - 12 = manufacturer-specific configuration (display / steering wheel controls).
13 - 20 = manufacturer-specific assignment (CD changer / DAB).
Connector pinout - ISO standard (chamber B).
1 = Right rear speaker (+).
2 = Right rear speaker (-).
3 = Right front speaker (+).
4 = Right front speaker (-).
5 = Left front speaker (+).
6 = Left front speaker (-).
7 = Rear left speaker (+).
8 = Left front speaker (-).
Connector pinout - ISO standard (chamber A).
1 = Speedometer pulse (for speed-dependent volume or navigation, depending on the manufacturer).
2 = Mute phone (depending on the manufacturer).
3 = Mute phone (depending on the manufacturer).
4 = Constant power +12V (terminal 30).
5 = Switching voltage for antenna or amplifier (remote control).
6 = Dashboard lighting (terminal 5icon_cool.gif.
7 = switched positive (terminal 15, via ignition switch).
8 = Ground (terminal 31).
You can also find color-coded diagrams with the corresponding pin assignments on the autoextem-forum (source for pin assignments).
http://www.autoextrem.de/showthread,t-1081.htm
Translated on 02-10-2026, 14:56.
No new posts Golf 5 Radio Volume Problem - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Radio: Won't Turn On After Parking? (8Z0) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Radio Connector: Golf 2000s Wiring Diagram Diesel Engine Technology
No new posts 1Z MSG connector pinout On-Board Diagnostics (OBD)
No new posts Pinout of the MFA (Golf IV) Transmission, Chassis, Body & Interior
No new posts OBD2 Pinout: Connector and Wiring Explained Diesel Engine Technology
