AC Fan Starts Briefly: Troubleshooting Guide
cksIT
Post28-08-2007, 15:43    Subject: AC Fan Starts Briefly: Troubleshooting Guide Quote
A colleague has a Leon (1M) with a 150PS TDI engine. Shortly after turning on the air conditioning, the fan runs at full speed for a few seconds. Then it stops spinning (if the engine is cold) and after about a minute, it starts again for a few seconds.
"No idea if this is normal or not?? What controls the fan here? (Could there be a defective temperature sensor...)"
Translated on 06-10-2026, 14:33.
Post28-08-2007, 16:39    Subject: AC Fan Starts Briefly: Troubleshooting Guide Quote
My A3 does the same thing, but it's due to a blown fuse for the first fan speed.
Translated on 06-10-2026, 14:34.
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post28-08-2007, 19:48    Subject: AC Fan Starts Briefly: Troubleshooting Guide Quote
Hi.
"In both fans, the pre-resistors for the first fan speed setting have burned out. This was also the case with my Golf. It happens to every second one!"
I hope I could be of assistance.
P.S. Both fans cost approximately €300 new from the dealer. And it's always both fans that are defective!
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which means "Sincerely" or "Best regards" in English.
Audi SQ5 8R Cvub
Translated on 06-10-2026, 14:35.
Back to top Profile PM Email
cksIT
Post28-08-2007, 21:34    Subject: AC Fan Starts Briefly: Troubleshooting Guide Quote
how?
Do I have to replace both fans??? Can't I just replace the pre-resistors separately?
Is there a way to test and confirm that both are actually defective, or is it just a matter of guesswork?
Translated on 06-10-2026, 14:36.
pa-mm6
Post28-08-2007, 21:41    Subject: AC Fan Starts Briefly: Troubleshooting Guide Quote
Hello.
Unfortunately, the pre-resistors cannot be replaced. The problem is that as soon as one resistor burns out, the second one receives too much current and also burns out very quickly.
The first fan speed usually turns on immediately when the air conditioner is activated.
Audi SQ5 8R Cvub
Translated on 06-10-2026, 14:37.
cksIT
Post28-08-2007, 22:29    Subject: AC Fan Starts Briefly: Troubleshooting Guide Quote
"That is, he notices that the first stage isn't working and therefore repeatedly triggers the second stage... Is there nothing stored in the error memory? (I need to check myself)."
pa-mm6
Post28-08-2007, 22:31    Subject: AC Fan Starts Briefly: Troubleshooting Guide Quote
HI.
cannot be read out via diagnosis.
Audi SQ5 8R Cvub
Translated on 06-10-2026, 14:38.
renwal
Post29-08-2007, 16:19    Subject: AC Fan Starts Briefly: Troubleshooting Guide Quote
You can also fix it yourself; it's been working perfectly for me for the past 3 months.
http://www.ms-kreativ.de/env/download/ReparaturGolfLuefterVorwiderstand.pdf
renwal
cksIT
Post29-08-2007, 16:28    Subject: AC Fan Starts Briefly: Troubleshooting Guide Quote
"Thank you!"
I'll pass it on and see if it works again icon_smile.gif.
Translated on 06-10-2026, 14:39.
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Spin-Up After Start Diesel Engine Technology
No new posts Climate Change: Where is the Vaporizer? Transmission, Chassis, Body & Interior
No new posts 1.9 TD Diava with Climate Control Transmission, Chassis, Body & Interior
No new posts Best Climate: Tips & Solutions Transmission, Chassis, Body & Interior
