Passat 3C: Raise Ride Height with Auto Leveling
megaonkel
Post18-04-2007, 19:23    Subject: Passat 3C: Raise Ride Height with Auto Leveling Quote
Hello, I've been driving a Passat 3C sedan with a 125 kW TDI engine since September, and unfortunately, there was no factory option available for an off-road suspension or similar.
Common "lift kits" like those from Seikel or WEITEC do not offer a mechanical lift, among other reasons because my 3C has rear suspension with automatic leveling.
SEIKEL suggested in an email that I contact Volkswagen to inquire whether it's possible to achieve a "lift" or increase in ride height through the automatic leveling system, and that this "lifting" is likely controlled electronically.
Therefore, I think I will also get a corresponding answer here in the forum (hopefully icon_wink.gif)?
Is it possible to use VAG-COM and the corresponding control units to raise the vehicle by approximately xxx cm? I know it would only affect the rear, but there are (mechanical) lift kits available for the front.
Thank you for your answers!
Translated on 08-08-2026, 16:50.
Ross-Tech-Support
Post21-04-2007, 12:47    Subject: Passat 3C: Raise Ride Height with Auto Leveling Quote
Please post a diagnostic log first, so we can see which control unit is responsible for the leveling system and whether we can help you. icon_smile.gif
Translated on 08-08-2026, 16:51.
Malte1408
Post21-04-2007, 13:36    Subject: Passat 3C: Raise Ride Height with Auto Leveling Quote
Hmm, I'm not sure if the Passat 3C even has electronic level control, but if your level control is only on the rear axle, then it's probably what's called a "nivel," which is entirely mechanical.
It's a special type of shock absorber that uses the spring movements to provide damping force.
Translated on 08-08-2026, 16:52.
Ross-Tech-Support
Post21-04-2007, 13:43    Subject: Passat 3C: Raise Ride Height with Auto Leveling Quote
Okay, that's exactly what it's about. icon_biggrin.gif The diagnostic log will very likely clearly indicate that there is no controllable control unit where you could adjust anything...
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Engine running via K-line," VCDS On-Board Diagnostics (OBD)
No new posts Tuning: Adapting via Channel On-Board Diagnostics (OBD)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Raise Vehicle with Gas Shock Absorbers? Transmission, Chassis, Body & Interior
