What do you think?
However, I can require that people are familiar with their own car.
the hit:
Customer arrives for inspection with an Opel Rekord 2.2.
'By the way, could you take a look at that? There's a red light flickering on the dashboard.'
red alert
'... yes, I will do it.'
'I managed to extract 0.25 liters of oil from the old 2.2-liter cast iron engine block.'
or:
In the middle of the night. A poor housewife is standing in front of her Corsa, and nothing is working...
Well... it involves exciting the molecule using an external ion source. But what is it?
The light switch creaks and emits strange odors.
'Her light switch is obviously broken.'
'Yes, it's been making those strange noises for about a half year, and sometimes it smells funny. But with a little shaking, it usually works.'
red alarm
.... 'well, they probably shouldn't park their car near houses, due to the fire hazard. Hopefully, the battery won't be strong enough to vaporize the cables and ignite the car.'
Please provide the text you would like me to translate from German to English. I will then give you only the translation, without any explanations.
After some MacGyver-esque tinkering with the plastic debris, the box was functional again, and the light turned off by pulling a fuse.
Perhaps an initial IQ test should be implemented before taking the driving test.
CU Gremlin.
