Solved: 1Z Power Loss Due to Overboost Pressure
zpeedster
Post17-11-2007, 21:04    Subject: Solved: 1Z Power Loss Due to Overboost Pressure Quote
Since last night, I've been experiencing a loss of power with my 1Z engine in my Passat 35i.
The following happens:
It behaves normally until the boost pressure rises, not to the usual level of approximately 1.1 bar as indicated, but instead increases to around 1.3-1.5 bar. After that, it drops very quickly and then rapidly increases again in the first four gears.
On the fifth gear, the same phenomenon occurs: the boost pressure rises again to 1.3 bar, then drops and remains low until you release the accelerator and press it down again.
I suspect it's probably due to a solenoid valve or something similar that limits or controls the boost pressure.
Boost pressure control valve / solenoid valve / N75.
028 906 283 F - €35.76
I hope you can help me with the diagnosis.
Translated on 24-07-2026, 22:56.
Post17-11-2007, 22:32    Subject: Solved: 1Z Power Loss Due to Overboost Pressure Quote
Either the turbocharger boost pressure control valve (N75) or its control circuit is faulty, or the small high-pressure hoses connecting the boost pressure line to the N75 and the turbo's pressure sensor are damaged.
For testing purposes, try bridging these hoses at the N75 valve (but use these two, not the ones from the air filter housing). The LD (boost pressure) should then settle just above 0.6 bar, and definitely not exceed 1 bar. If that's the case, then it's likely the N75 valve; otherwise, it's probably the hoses.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It refers to a sudden and strong gust of wind.
Translated on 24-07-2026, 22:58.
heizfoss
Karma: +4 / -1   Thank you, like it!
Post27-11-2007, 0:03    Subject: Solved: 1Z Power Loss Due to Overboost Pressure Quote
and do it soon, otherwise you'll end up like I did two years ago. icon_sad.gif
The solenoid valve is defective (~35€), but by the time I found it (I followed the same procedure as described by Guste above - thanks to the forum icon_razz.gif), I had already replaced several "burst" charge pressure hoses for a total of 70-80€.
And actually, I can still be glad that not more broke icon_wink.gif.
heating fossil
icon_smile.gif Spritsparen durch Ausnutzen der Querbeschleunigung - lieber tot als Schwung verlieren
Translated on 24-07-2026, 23:00.
zpeedster
Post14-12-2007, 10:29    Subject: Solved: 1Z Power Loss Due to Overboost Pressure Quote
It was the valve.
So, the problem is solved.
Post14-12-2007, 14:16    Subject: Solved: 1Z Power Loss Due to Overboost Pressure Quote
Thank you for the feedback!
Translated on 24-07-2026, 23:01.
This topic is locked, you cannot edit or reply. Third gear shifting/synchronization (resolved) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 1Z with excessive boost pressure Upload
No new posts A4 TDI: Limp Mode Due to High Boost Pressure On-Board Diagnostics (OBD)
No new posts BKD 2.0 16V TDI: Turbocharger boost pressure limit exceed... Diesel Engine Technology
No new posts Boost Issues Solved: Troubleshooting & Fixes On-Board Diagnostics (OBD)
